Old 19th June 2007, 06:33 AM   #1
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default Please recommend a 15" woofer for a dipole
Some time back I was very impressed with a dipole posted by Felixx on the Systems thread.
This is one pic
http://www.diyaudio.com/forums/attac...amp=1177614049
more here...
System Pictures & Description
My room is about 300 sq. ft with a 9.5 ft ceiling and I am thinking of building somethnig like this.
The speaker would be about 6" deep x 18" wide x 32" tall so at best it would accomodate 2 15" woofers.
What are the choices?
Eminence (Beta 15A?)?
anything better with a rubber surround?
the rest would be managed by a 6" 2way in a shallow sealed box above the subwoofer. Based on the Orion+ I might even use a second rear firing 6" and/or tweeter. I have not chosen these drivers either but am favouring the SEAS Excel series or the Scan Speak Revelator series.
The speaker will be triamped with tubes for the midbass and tweeter.
...still looking for the holy grail.
Old 19th June 2007, 06:58 AM   #2
adason is offline adason  United States
adason's Avatar
Hawthorne Audio Augie
http://www.hawthorneaudio.com/drivers.htm
Old 19th June 2007, 08:15 AM   #3
Scottmoose's Avatar
Eminence Beta15 wired & XOed in series with an FE167E makes a spectacular sound on a fairly small U-frame.
Old 19th June 2007, 09:51 AM   #4
navin's Avatar
I did consider the 167 but given the demands of this speaker I think a 2 way would be better suited. Any othe 15" that would be more suitable than the Beta 15?
The iris 15 suggested earlier has a Xmax of only 3.5mm.
Old 19th June 2007, 10:14 AM   #5
You wanna build something like this ?
Old 19th June 2007, 10:15 AM   #6
Maybe Peerless 830867
Old 19th June 2007, 10:16 AM   #7
tinitus is offline tinitus  Europe
Eminence drivers might be a very good choice with fullrange drivers like FR167 or Hemp 8"
With "standard" 2way drivers there might be better options - maybe the "cheap" and interesting Mach5 18" IXL sub driver, very low Fs
BohlenderGraebender NEO-3/RAW is a dipole ribbon
The Peerless suggested by Andrew could be very good, but it has a low Qts=0.28 and might not be suited fore dipole, or may it be corrected with EQ - looks like a very nice driver with low Fs and high SPL, but maybe a bit expencive fore the technology
Old 19th June 2007, 10:43 AM   #8
soundcheck's Avatar
I built these myself:
Based on 2*2* BD15 drivers and Ripol/Linkwitz Design
http://www.bd-design.nl/forum/forum_entry.php?id=11047
Cheers
Old 19th June 2007, 11:11 AM   #9
Personally I'd like to hear those Jamos..........
Someone should start a "clone" project of them......
Old 19th June 2007, 11:40 AM   #10
navin's Avatar
I dont care for the looks of the Jamos. I like the looks of the speaker felixx built, but yes the idea is the same.
tinitus, I am not confident on the sound I will get from a fullrange consider a lot I listen to is rock and jazz.
For a dipole I assume the Qms and hence the Qts would have to be high (above 1.0 or so). This is what I have been led to believe. Please correc me if I am wrong.
sound check, what are the specs of the BD 15 15" woofer you used? Where are they available?
BTW, Should I go for a push-push pair for the midbass and tweeter? Drivers I am looking at are :
6" woofer: Seas W18NX
1" tweeter: can one use a tweeter with no ferro fluid; I would be thinking of the Seas T25C03.
What are the disadvantage of ferro fluid?
Alternately the ScanSpeak 18W8546/8545K mated to the 9700 is another option.
Dipole Ribbon tweeter isolation from dipole mid-woofer array Bent Planars & Exotics 5 21st May 2009 12:10 PM
Recommendations for 6.5-8" woofer/midrange as a dipole Samppo Multi-Way 11 3rd October 2006 12:55 PM
Please recommend enclosure for this woofer Cro maniac Multi-Way 3 4th August 2004 12:22 PM
Please recommend a woofer. 1Time Multi-Way 17 5th February 2003 05:39 AM
Page generated in 0.10758 seconds (77.73% PHP - 22.27% MySQL) with 11 queries
