The strangest thing
The strangest thing
Old 27th January 2003, 04:08 PM   #1
Nielsio is offline Nielsio  Netherlands
Nielsio's Avatar
Default The strangest thing
Well peoples, right now I'm listening to a very abnormal speaker system. Normally, I have an open-baffle speaker with a 12" Supravox and an 8" AER, XO at 300 hz. But I wanted to try something different. So I've put the entire speaker on a box, so that my 12"-ers are about 2 feet from the ground, and I've connected them full-range (AERs do nothing now).
The Supravoxes are pretty wide-band themselves (to ~7 khz), but with brute force equalization (Behringer Ultracurve) they now extend way up ~16/17/18 khz.
http://perso.wanadoo.fr/supravox/eng...285%20GMF.html
The results: I have to admit, this sounds pretty amazing. I have to get a better measurement, and fix some bumps, but the potential is so high! I hear more detail / differentiation of instruments etc than with my normal configuration.
With a top-end full-ranger you can't equalize that much LF, but with a low-end full-ranger, you can equalize a whole lot of extra HF, right?
Old 27th January 2003, 04:17 PM   #2
tiroth is offline tiroth  United States
Not really, although there may be an issue of degree that works to your advantage. Probably the amount you can EQ top end ends up being limited by linear excursion, and the amount you can EQ bottom end is limited jointly by beaming and intermodulation distortion.
Old 28th January 2003, 12:24 AM   #3
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
The strangest thing
Surely you mean the other way round tiroth?
Nielsio
Sounds to me like you were having phase or crossover problems with running the two drivers together. Before you get carried away I would check your wiring and XO. You can quickly and crudely check this by using your Ultracurve to output low to one driver and hi to the other using extreme cut and boost of the faders for the different channels. This will also give you a rough idea of where the crossover point should be, so you can check that at the same time.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th January 2003, 01:15 AM   #4
Nielsio's Avatar
Nielsio
I think you misunderstood me. It's probably on 'the AERs do nothing now'. I mean't to say that I haven't connected them in this configuration. So it's not a problem of some sort, but my intention.
So: the whole idea is to run one 12"-er fullrange, and equalize the top-end drop-off to around 16 to 20 khz.
So the main question is:
-Is this doable / will the 12" Supravox give out this amount of HF, or will it not be linear and cause some kind of distortion / and or intermodulation.
Niels.
Old 28th January 2003, 08:23 PM   #5
pinkmouse's Avatar
The strangest thing
Ahh, got where you're coming from
IM distortion and cone breakup could be a real problem, read Kelticwizard's comments on this thread and it will give you an idea why.
You could try measuring this with a sine wave generator and an FFT program, this will give you an idea of how bad it might be.
Old 28th January 2003, 08:40 PM   #6
slowmotion is offline slowmotion  Norway
slowmotion's Avatar
Hi Nielsio
Have you considered running the 12" Supravox
up as far as it will go, without eq, and then adding a tweeter?
Small horn or maybe a ribbon ?
- Jan -
Old 28th January 2003, 10:45 PM   #7
Nielsio's Avatar
Thanks. I'll look in to it.
Old 28th January 2003, 10:52 PM   #8
Nielsio's Avatar
Originally posted by slowmotion
Hi Nielsio
Yes, I have :-)
Fostex has a nice ~98 db tweeter. Supravox also. Ribbon, I'm not so sure (low efficiency).
PHY-HP and ESG3 (or how do you spell it) have very good ones, but are very expensive.
I think I'll have to do some experimenting with tweeter types, if I want to go for that. Also, if I do this, I think I'll go Bass-reflex (or closed) in stead of open baffle.
Niels.
Old 29th January 2003, 02:45 AM   #9
BAM is offline BAM
Send a message via AIM to BAM
I think one could get a nice warm tone from this, but I would suggest using it in a sealed box so that the cone does not try to go down too low. Of course, I'm not the expert on this, it's just my ideas.
Old 9th April 2006, 01:11 PM   #10
felixx is offline felixx  Romania
felixx's Avatar
Hi!
I have a same problem with 285.Maybe I think to add a tweeter is good but what do you think to add a very small one and put them (coaxical),by removing the dust cap and insert the tweeter on the same axe with magnet and gluing it.After that you could add dust cap over the tweeter.The crossover must be only a cap,maybe with a L-pad.
The tweeter must be very high spl. and also tiny.(1"tweeter-horn type).
I want to put them into MLTQWT or Voigt enclosure.
What do you think by that?
"I'm glad I can build my own mistakes."
https://picasaweb.google.com/115586837612433686520
The strangest thingHide this!Advertise here!
White Series 4000 EQ The strangest PSU design EVER. GLORY_MORRIS Parts 15 23rd October 2008 01:53 AM
Whats the strangest enclosure you found to work? Scioneer Full Range 0 20th September 2006 04:54 AM
The next big thing? pinkmouse Everything Else 7 15th August 2006 04:24 AM
next best thing kartsmart Digital Source 5 9th November 2005 11:38 PM
Your Nicest, Rarest or Strangest tube Netlist Everything Else 28 17th May 2003 04:20 PM
Copyright ©1999-2017 diyAudio
