Old 17th June 2007, 09:40 AM   #1
sokol is offline sokol  Poland
Default long xmax: pros and cons
what are the pros and cons of long xmax in bass guitar drivers?
For sure pro is high power whitstand ability at low frequency. Any other pros? Any cons?
Old 17th June 2007, 09:45 AM   #2
Did it Himself
richie00boy's Avatar
Linearity
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 17th June 2007, 03:05 PM   #3
Svante is offline Svante  Sweden
Svante's Avatar
In general:
A long xmax makes the driver capable of louder sound at low frequencies with less distortion.
A long xmax also reduces efficiency if the voice coil is underhung*; much of the coil is not subjected to magnetic field, which means that it will not deliver any force to the cone. It will just consume power and add weight to the moving system.
I can imagine that distortion is less of a problem in guitar loudspeakers, distortion may very well be a desired feature of the system. However, for hifi use, distortion is bad.
*Almost all drivers have underhung voice coils.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 17th June 2007, 03:12 PM   #4
Hartono is offline Hartono  Indonesia
Hi Svante,
"underhung*"
you mean overhung ?
Hartono
Old 17th June 2007, 07:17 PM   #5
Svante's Avatar
Originally posted by Hartono
Hi Svante,
"underhung*"
you mean overhung ?
Hartono
Yes, of course. Sorry.
Old 18th June 2007, 10:59 AM   #6
Sorry, did not understand "overhung". Does it mean, that coil is out of gap?
Old 18th June 2007, 11:03 AM   #7
yes the voice coil is longer than the gap
there's some way to keep linearity with overhung voice coil, this involve some technique in linearizing BL over excursion , and other techniques.
edit: usually if this technique is used in the driver, the manufacturer will mention it
Old 18th June 2007, 01:06 PM   #8
Svante's Avatar
Here are some pictures on over-/underhung voice coils:
http://en.wikipedia.org/wiki/Voice_coil
Old 18th June 2007, 02:50 PM   #9
I've found that one of the cons of high excursion drivers is fatiguing of the (rubber) surrounds. Because the surround is wider, it also has to be thicker, and it hardens after a while from all the flexing.
And maybe deep bass isn't the biggest problem? Lots of speakers can handle it. For a bass guitar I'm guessing you'll want deep bass and good performance up to around 400Hz, so that you can play a high G at ~196Hz and still reproduce the 2nd harmonic with a good 'attack'. How about using an array of smaller drivers instead of a single large one?
Lech
Old 18th June 2007, 02:58 PM   #10
I think for bass guitar application , the linearity is not the important one, the important one is how the end result "sound"
warm, full of tone , deep ... etc
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 12:57 PM
TL vs MLTL, pros and cons Tomac Multi-Way 5 29th December 2004 12:55 PM
Filterless DAC - pros and cons? mr_push_pull Digital Source 1 11th August 2004 02:56 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 05:37 PM
Page generated in 0.08609 seconds (84.79% PHP - 15.21% MySQL) with 10 queries
