Old 16th June 2007, 08:16 PM   #1
thadman is offline thadman  United States
Default long or short ribbon for 4khz+?
I'm designing a dipole WWTMWW and have to decide what high frequency tweeter I'm going to use for the region 4khz-20khz. All of the drivers will be operating dipole (RS225s are open baffle and the RS52 and ribbon will be front and rear firing).
I have to decide between a short ribbon or long ribbon. I don't want to spend >$500, but less is always better. I am currently considering the Fountek NeoCD2.0 (120mm ribbon), Fountek NeoCD1.0 (1.5" ribbon), and the Aurum Cantus G2si (I can get these for $60/each).
short ribbon
advantages:
-shorter length allows closer CTC spacing for RS225s in WTMW
-much wider vertical dispersion (1.5" vs 5"...pretty significant difference)
-cost 1/2 $
disadvantages:
-poor efficiency and lower maximum output (by ribbon standards), the NeoCD1.0 hovers around 90dB
-poor non-linear distortion
long ribbon
advantages:
-incredible efficiency, the NeoCD2.0 is between 98-100dB over its operating range
-better distortion performance
disadvantages:
-height makes CTC spacing difficult
-extremely poor vertical dispersion
-cost $120-130/each
At this point, I'm leaning towards the NeoCD1.0 if it's dynamically capable. If we assume 90dB efficiency and add 6dB for baffle step and another 6dB for dipole radiation, we achieve 102dB. If we increase power to 16 watts, we're able to achieve a maximum of 114dB. Is this high enough for most dynamic recordings?
Is baffle step already figured into the sensitivity of the tweeters?
Is the vertical dispersion of ribbons (even short ones) already poor enough that they absolutely require on-axis listening? Adjusting the vertical height ribbons so that my ears lie within the 5" length of the NeoCD2.0 seems doable...but wildly impractical with the NeoCD1.0.
long-thin vs fat-short TL Henkjan Full Range 26 22nd October 2006 07:54 PM
Long excursion vs short Hayden Car Audio 19 5th March 2006 07:47 AM
Short vs. Long MLTL rdf Multi-Way 6 15th September 2004 04:41 AM
Page generated in 0.05786 seconds (70.00% PHP - 30.00% MySQL) with 10 queries
