Speakerholic
If you have a set of speakers with front and rear chambers and a plate amp on the back along with a woofer and a 3 way on the front as seen in the picture, is that known as a bi-amped 4 way or does it qualify as a 3 way 2.2 system? Does the .2 necessarily indicate a separate cabinet for each woofer?
EDIT: the front midbass has a high pass filter on it. Curious Cal wants to know. |
#2 |
Just to display my ignorance; if the front mounted midwoofer has a high pass filter, does the plate amp have the usual High/low second order filter and is the high pass on the midwoofer a single cap or is it more complicated than that??
Nomenclature seems to depend on who builds it. I have always thought that my towers were just nonstandard three ways but in another forum I was told emphatically that had to desribe them as a 4wayby one person and 3.5 way by another: is there a convention we should be working towards?? ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#3 |
High pass filter means it's a bi-amped 4 way. If there was no high pass filter it would be a 3-way with subwoofer
#4 |
My vote goes for bi-amped 4 way.
4 drivers, covering 4 frequency ranges (assuming no overlap between midwoof and sub). With overlap, bi-amped 3.5? |
#5 |
well, 3.5 way in my understanding has always been when you use two of the same woofer to cover different frequency ranges. (ie. two of whatever the largest woofer is, one with a high-pass filter, one without)
#6 | |
True. My mistake. |
#7 |
frugal-phile(tm)
Cal,
It is a biamped 4-way. In an x.5-way system an even number of (usually identical) woofers of mid-woofers with half of the drivers covering the range up to the next driver (mid or tweeter) and going all the way down. The other half (0.5 driver(s)) of are crossed over below the baffle-step to fill in the BS loss. XO on the 0.5 unit(s) is usually 1st order. A 2.2 system would refer ro an HT system with Left & Right and 2 subwooders feed LFE channel(s) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 | ||
Speakerholic
#9 | |
frugal-phile(tm)
dave
#10 |
Speakerholic
OK gotcha. Thanks Dave, now I can sleep at night.
| what is this called | skullkeeper | Parts | 1 | 23rd April 2009 11:28 PM |
| What is this Amp design called? | packer | Solid State | 2 | 1st March 2009 12:11 AM |
| What is this cap called? | intensem1rider | Parts | 6 | 20th March 2008 05:34 AM |
| What is this topology called? | teemuk | Solid State | 7 | 27th July 2007 09:52 AM |
| What is this connector called? | megajocke | Parts | 10 | 7th February 2007 06:10 PM |
| Page generated in 0.10663 seconds (82.23% PHP - 17.77% MySQL) with 11 queries |
