Old 14th June 2007, 04:20 AM   #1
Moondog55's Avatar
Question A new speaker project # 1
Quote from me
"The more I know, the more I know I know nothing"
I need a pair of speakers for the computer room, as my partner and I send a lot of time in here.
It is a small room, measures (metric) Floor to ceiling 2600mm , Width 2650mm, Depth 2750, it has a plasterboard ceiling and walls and has 3 computer towers and associated work-stations and book cases lining 2 walls, very big plate glass windows and obviously a door.
My current speaker set-up uses a Behringer Super X Pro; CX –2310, and an assortment of amps and inputs.
We tend to listen to music from hard disk in here so the computer is the main source.
My current speakers comprise a modified DickSmith 5inch 2-way with the tweeter replaced by a high-end Jamo silk dome and the crossover changed to 2nd 3rd at 4000hz and a pair of CerwinVega 12 4’s which are currently crossed at 200.
My question contains 4 parts; which perhaps need threads of their own, but if so I will start new threads.
I have accumulated several sets of drivers with different needs in mind:
Q1/ Is it a waste to use a high-end mid-range like the Vifa M11MH-09-08 and D26 tweeter with a cheap woofer?
Q2/ My budget is limited for the next couple of months and can anyone recommend a woofer suitable for a sealed box, using these drivers and help with crossover design (as yet I don’t own any software)
I have looked at the Visaton
http://www.soundlabsgroup.com.au/pc/...isaton-8/Sound
And also
As well as
https://secure4.vivid-design.com.au/...Max=&SUBCATID=
Q3/ Am I better off using a cheap woofer and a different choice of mid-range and tweeter? I do have a reasonable 5inch ‘Response” from Jaycar and some Vifa D26NC’s.
Q4/ Does any-one have any experience on laminating chipboard to MDF and using the composite to build speakers?? It is not constrained layering but I would appreciate comments on this thought before I purchase the sheets and glue.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 14th June 2007, 05:04 AM   #2
sqlkev is offline sqlkev  United States
-IMO, no. You can always add a better sub at a later time. Assuming you're going for an active setup since you've got several amps to use and the behringer piece.
http://www.soundlabsgroup.com.au/pc...Visaton-8/Sound
And also
As well as
https://secure4.vivid-design.com.au...eMax=&SUBCATID=
- I like the ma26wr in a small sealed box, but the peerless subs would work great for your setup too.
-Like I've mentioned above, probably best if you start out with the better drivers.
I've always built speakers out of birch ply or mdf, no chipboard+mdf yet. I don't see the benefits to it.
One suggestion since you're using the computer as source, use a good soundcard.
Old 14th June 2007, 07:29 AM   #3
Moondog55's Avatar
Default MDF plus chipboard
I made a big Quad box a while ago and noticed that where I had used chipboard(particleboard) for a stiffening; panel resonace was lower than where I had used MDF, and having read a discussion on constrained panels I was thinking that it was the glue layer acting as a constrained layer in itself.
Chipboard is a LOT stiffer than MDF, you can't use it for a bookshelf for instance but MDF is deader.
I was just wondering if any others had experimented in this direction
Old 14th June 2007, 08:26 AM   #4
Moondog55's Avatar
I would also like this one to be a passive X-over and reserve the active for another project
Old 14th June 2007, 09:33 AM   #5
Andy G is offline Andy G  Australia
Andy G's Avatar
Default Re: A new speaker project # 1
AG1: It depends on the cheap woofer: I use the Jaycar 10" poly in "Blackwood", it isn't expensive, but it is very good at woofer duty up to about 300-400Hz.
AG2: Sorry, haven't used the Visaton's YET, so can't comment
AG3: The 5" Jaycar is not reasonable, IMO it is muddy and indistinct in the mids, not what you want with the Vifa D26NC, which is a rather nice tweeter (see Zaph's comments about the Vifa)
AG4: Laminate ply to MDF, that way you can use faced ply and get a nicer looking speaker. I would steer clear of chipboard myself.
catch ya.
Old 14th June 2007, 02:11 PM   #6
Speakerholic
Cal Weldon's Avatar
Default Re: MDF plus chipboard
Question:
http://www.diyaudio.com/forums/showt...62#post1232762
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Help with speaker project davethomp Multi-Way 3 5th March 2009 12:18 AM
Speaker Project mot on/off Multi-Way 6 19th November 2007 05:11 PM
My first Speaker Project :) Robertburchell Subwoofers 9 7th July 2006 03:11 PM
speaker project help minh_827 Multi-Way 7 26th April 2005 06:33 AM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.10459 seconds (80.95% PHP - 19.05% MySQL) with 10 queries
