Old 14th June 2007, 06:13 AM   #1
dm1179 is offline dm1179  Philippines
Default Loudspeaker Quality Measurement
to the guru's, please help. how do you measure total rms power? example, in the spec sheet of the speaker, it is stated"15W RMS into 4ohms at 100Hz at 10% THD".. how do you measure the 15W RMS? another is "System THD: Better than 0.05% THD before clipping". how do you measure the THD (total harmonic distortion)? last is "Signal to Noise Ratio: >80dB". how do you measure ang SNR? what are the test equipment needed.
thanks.
Old 14th June 2007, 07:57 AM   #2
Did it Himself
richie00boy's Avatar
They just assume it 's a nominal 4 ohm load, then put a distortion measuring kit on it. Turn it up until you register 10% THD, then see what the drive voltage is. Use that to work out power into 4 ohms.
System THD before clipping, I would imagine is an amplifier measurement. Ditto the signal to noise ratio.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Loudspeaker measurement using SMAART live ? Empee Multi-Way 3 12th August 2009 03:50 AM
Recommendations on pc audio interface for loudspeaker measurement diypole Multi-Way 9 15th July 2009 12:45 PM
What really matters? Quality loudspeaker design. Rounder Multi-Way 15 6th November 2007 08:17 AM
Sound card for loudspeaker measurement preiter Everything Else 8 13th August 2007 12:32 AM
Easy Loudspeaker Measurement System Set Up hongrn Multi-Way 3 24th July 2006 08:56 PM
Page generated in 0.06496 seconds (72.20% PHP - 27.80% MySQL) with 10 queries
