#1 | |
8=lambda/4. lambda=32, lambda=13,397/32, lambda=418.65hz How does Linkwitz avoid this phenomenon with his front and rear firing Milleniums? |
#2 |
You can avoid that by dimension the cabinet correctly.
Houston, we have a problem! |
#3 | ||
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 | |
The Millenium drivers are closed in the back, so this phenomenon does not apply.
www.dipolplus.de |
#5 |
Sorry for my awful english..
I’m from italy and I’m not able to write very well I think that what Rudolf wrote is correct, the described phenomenon of resonance regards two speakers sharing the same volume. Millenium tws have separate volumes.. I’ve made a prototype of dipole speaker like the one suggested in a figure of the Linkwitz site. Here are some photos.. ![]() ![]() ![]() ![]() I’ve investigated about the resonance described by Linnkwitz but I was not able to find this type of problem.. My prototype seems not to have this issue. Any suggestion and comment is well accepted.. Thanks |
#6 |
It appears you have front and rear firing cone midranges. How much more energy is required to drive them into xmax at high frequencies (say 160-200hz) as compared to a conventional open baffle?
#7 |
From an aesthetic, diffraction, and perhaps cleaner rear radiation standpoint, having dedicated rear firing cone midranges (down to 160/200hz) would be very nice. I wouldn't have to transition (from an aesthetic and diffraction point of view) from the 8" deep midrange cabinet to the open baffle panel of the RS225s. If I decided to preserve the roundover down the entire length of the cabinet, the cone midranges would be within a 4" deep quasi u-frame creating a resonance. If I went with front and rear firing cone midranges, that resonance could be avoided by seperating the air volumes of the midrange drivers. The Daytons aren't that expensive to begin with and justifying an extra $100-140 for rear radiating drivers would be very easy. |
#8 | |
![]() I’m not so able to understand English correctly If u r talking to me I could answer that separating air volumes of midrange could be a good idea regarding resonance but I think that the important “no box sound” of the open baffle will be lost.. I have think a lot about the resonance problem due to the length between drivers.. My opinion is that sound wave stars from the back of each driver, go towards the other driver and meet the other loudspeaker wave that is reverse of phase.. In that point we probably have the waves deletion.. I “probably” could be in wrong.. Thanks |
| Front firing vs down firing sub? | alex_g | Subwoofers | 32 | 22nd June 2010 12:34 PM |
| Dipole speaker with monopole rear firing midbass? | GuyPanico | Multi-Way | 4 | 12th November 2005 02:49 PM |
| Woofer: side firing pair vs front firing? | tcpip | Multi-Way | 13 | 9th September 2005 02:13 PM |
| searching software to switch front speakers to rear and rear to front!-dolby surround | MCM | Everything Else | 6 | 6th February 2004 09:29 PM |
| Horn at front, transmission line at rear? | Circlotron | Multi-Way | 2 | 7th October 2003 07:57 PM |
| Page generated in 0.09913 seconds (81.47% PHP - 18.53% MySQL) with 10 queries |
