#31 | |
#33 |
Actually 0 Hz can be interpreted in many different ways.
One would be like the professor next door to me says: "frequency is the same as 'often-ness'". From that definition, 0 Hz would mean that the event that we study has never happened. Like: At what frequency has God created earths (ok, bad example for religous people ).Another one would be Fourier analysis. A signal only containing 0 Hz would be a signal that has been and will be forever "on" at a fixed value. Even before big bang, it was on. This is of course not possible. Yet another way would be to make Fourier analysis of a snippet of a signal (this is the way we usually do it). By doing so we limit the frequency resolution and each frequency bin will have a non-zero width. In this case, the DC of the signal comes out in the 0 Hz bin. |
#34 | |
Speakerholic
Did I get that right? |
#35 | |
Yes. |
#36 |
expert in tautology
The fan works for me. Unidirectional flow = DC = No Hertz at all.
With laminar air flow, if you want to get into it deeper. Thus, by extrapolation we have those woofers that actually use a fan. _-_-bear
_-_-bear http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
#37 |
Hi Bear,
"Thus, by extrapolation we have those woofers that actually use a fan." you mean THAT woofer ? I'll go with aircon, much cooler and cheaper. Hartono |
| taking a W3-871S to 80 hertz | Douwe | Full Range | 86 | 30th October 2009 06:08 PM |
| Help!...it hertz | crick | Full Range | 9 | 2nd July 2007 08:34 PM |
| Hertz ML-5400 D | make72 | Subwoofers | 14 | 14th January 2005 04:50 PM |
| Difference between Hertz HS-200 and HX-200 | FaZ72 | Multi-Way | 2 | 8th April 2004 01:34 PM |
| Hertz or Cycles? | Bob2 | Everything Else | 10 | 9th June 2003 11:50 PM |
