Zero hertz - Page 3 - diyAudio
Old 13th June 2007, 11:53 PM   #21
Sonusthree's Avatar
Originally posted by darkfenriz
atmosferic pressure, the "DC" for all music, which is AC
Aaah! I thought you were just being crazy but ............
I guess you're saying that air pressure,fairly constant and therefore somehow analogous to D.C., is being modulated by the movement of the diaphragm/cone/panel etc. (Music).
Right?
Old 14th June 2007, 12:50 AM   #22
pinkmouse's Avatar
Thought experiment:
Imagine you have an old pendulum clock. When the pendulum is swinging, at any speed, (frequency), then then you can use it to tell the time. No matter what speed it swings, you can use different gears to make it work. However if you stop the pendulum swinging, no mechanism that you can attach to the clock will make it tell the time. Therefore the concept of zero Hz is meaningless.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 14th June 2007, 01:12 AM   #23
Sonusthree's Avatar
Originally posted by pinkmouse
......Therefore the concept of zero Hz is meaningless.
I understand what you're saying and I agree that zero Hz is mathematically meaningless until I get to daydreaming .................
A speaker/pendulum continually reduces it's frequency ..... 10Hz .... 1Hz ..... 0.1Hz .... 0.000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000000000000000001Hz
What comes next? Yes, I do know, but it's interesting and you get what I mean! Surely this number is more than a reasonably accurate representaion of 0Hz.
To me, it's like trying to comprehend all the stars in the universe ..... or .... the universe.
I think I'll just try to counteract tonight's insomnia by accepting that 0 Hz = Stop.
Old 14th June 2007, 01:21 AM   #24
pinkmouse's Avatar
Originally posted by Sonusthree
...What comes next?...
That's what we have calculus for.
Read up on Zeno's paradoxes, particularly the arrow in flight - that's a similar case.
Old 14th June 2007, 07:20 AM   #25
Keruskerfuerst's Avatar
Since DC is electrons flowing continuously in one direction, wouldn't it push the cone out (or pull it in depending on polarity) and just leave it there?
Only a AC current creates a electromagnetic field. A DC current does not.
Old 14th June 2007, 09:16 AM   #26
pinkmouse's Avatar
How come I can make an electromagnet out of an old nail, a coil of wire, and a 9V battery then?
Old 14th June 2007, 09:31 AM   #27
is that the difference between a dynamo and an alternator?
one produces DC and the other produces AC (that needs to be rectified).
Both machines depend on electromotive force and electromagnetic field.
BTW,
what is chopped DC?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 14th June 2007, 09:51 AM   #28
pinkmouse's Avatar
Both machines depend on electromotive force and electromagnetic field.?
To save me the typing, here's the wikipedia reference.
BTW, what is chopped DC?
Chopped DC varies between the given voltage and ground, and AC varies in relation to ground, so goes negative as well as positive. At least, that's how I understand it.
Old 14th June 2007, 07:10 PM   #29
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
A speaker/pendulum continually reduces it's frequency ..... 10Hz .... 1Hz ..... 0.1Hz .... 0.000000000000...00000000000001Hz
nah a pendulum of a given length will always swing at the same frequency, regardless of amplitude.
unless of course the amplitude is zero.
high school physics.
Old 14th June 2007, 09:25 PM   #30
BHD is offline BHD  United States
BHD's Avatar
Send a message via Yahoo to BHD
Try hooking up a battery to a woofer and see what happens...
Then reverse the polarity.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first.
taking a W3-871S to 80 hertz Douwe Full Range 86 30th October 2009 07:08 PM
Help!...it hertz crick Full Range 9 2nd July 2007 09:34 PM
Hertz ML-5400 D make72 Subwoofers 14 14th January 2005 05:50 PM
Difference between Hertz HS-200 and HX-200 FaZ72 Multi-Way 2 8th April 2004 02:34 PM
Hertz or Cycles? Bob2 Everything Else 10 10th June 2003 12:50 AM
Copyright 1999-2017 diyAudio
