Old 13th June 2007, 01:41 AM   #1
Default BR/Aperiodic hybrid? can this be done?
After looking at the distributed port designs I have wondered if it is possible to create a speaker that has the characteristics of a BR and a aperiodic loading.
To tune a box at a certain frequency you need a vent of a certain size. We know that the smaller the vent area the shorter the vent has to be.
So here is my thinking. If we calculate the box size and tuning frequency and then make the port small enough so that the length of the port is the thickness of the wall material then the port is small enough that it creates as resistive flow.
Then to adjust the resistance amount we make several small ports near each other until we have the right amount of resistance. So this is really just a distributed port made up of several small holes.
But is it possible to balance the acoustic resistance with the tuning so that you got a balance of BR and aperiodic behavior?
Old 13th June 2007, 02:11 AM   #2
Sure. That is what the distributed port design is about.
You can also add stuffing to a single port to get the same effect.
At the tuning frequency, the impedance gets higher, cone motion increases and the port output decreases. While never used for PA, many hi fi builders and manufacturers prefer the sound to the unrestricted port.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 13th June 2007, 03:57 AM   #3
Nanook is offline Nanook  Canada
Nanook's Avatar
Default one way to do it is ...
as Bill Perkins of PEARL did it. Tune a box, stuff the port full of straws. Makes even a horrible design sound great. Another way is as used in an Onken enclosure, or as per Variovent designs.
stew -"A sane man in an insane world appears insane."
Aperiodic boxes with aperiodic TL's - an idea. Shoog Full Range 0 22nd May 2009 05:03 PM
Aperiodic enclosures Geoff H Multi-Way 65 17th May 2009 08:24 AM
Hybrid aperiodic / ML TQWT Hezz Multi-Way 0 2nd March 2007 05:30 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
How to Design an Aperiodic Box? KT Multi-Way 1 12th August 2005 05:40 PM
Page generated in 0.07224 seconds (75.43% PHP - 24.57% MySQL) with 10 queries
