Trying to use Speaker Workshop to measure impedance.
I have been through all the calibration steps and have succesfully managed to measure passive components within close tolerances. I have no problem measuring free air impedance of woofers. AS expected, I see the Fs of the driver and rising impedance with frequency. However, when I measure tweeters - there is no resonant frequency at all. The impedance is flat until the natural rise toward the top end of the frequency range. I am using a cable jig with an 8.2ohm resistor. Attached is the tweeter free air impedance measurement. Any help much appreciated Thanks, David. |
#2 |
PS: I have measured 2 different tweeters and woofers. Attached below is the Wharfedale woofer
No setup changes were made between measurements (other than switching drivers over). |
#3 |
What type of tweeter are you using?
Houston, we have a problem! |
#4 |
Sorry - should have said.
The image posted is a 3/4" metal dome tweeter (Wharfedale proprietary). The other tweeter I tested is a Vifa D19-TD-05 fabric (plastic?) 3/4" dome. The Vifa plot is below (similar symptoms). Both tweeters were removed from working speakers so nothing wrong with the tweeters. I have tried different sample sizes, rates, repeat counts to no avail. Thanks, David. |
#5 |
Did it Himself
Do the tweeters have ferrofluid?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
I'm not sure. It looks like I can remove the faceplate on the Wharfedale tweeter but am reluctant to do that.
Good thinking... I thought "maybe this is a case of ferrofluid flattening out the resonant peak", but surely even the most damped / fluid filled tweeters have some sort of peak? (even if only a few dB above nominal?) They both seem too flat - even for ferrofluid tweeters. From memory, I don't think the Wharfedale's do. I couldn't find the D19 spec in the Tymphany archive pages. will google it now. Cheers, David. |
#7 |
Did you do the interchannel latency calibration?
Hear the real thing! |
#8 |
Hi soongsc,
Yes I did. Found -14usec flattened the phase rise toward the upper end as shown in the attached image (zoomed in) I also found a 500msec latency got the MLS pulse starting consistently around 400msec. Cheers, David. |
#9 | |
If it is, then it seems the tweeter impedance must be right. I also have a tweeter that has a flat impedance and flat phase as well.
#10 |
Possible reasons for "flat" impedance curve:
1. Ferrofluid 2. copper short circuit rings.
| speakers operating near their resonant frequency | kanguru007 | Multi-Way | 26 | 28th March 2009 02:02 PM |
| Ribbon Tweeter Resonant Frequency | DamageG | Planars & Exotics | 2 | 14th February 2008 05:30 AM |
| Reverse engineering resonant frequency | jonkun227 | Multi-Way | 13 | 12th April 2007 05:33 PM |
| What about resonant frequency? | Javachip | Full Range | 6 | 15th June 2006 06:12 AM |
| Resonant Frequency of an enclosure | AudioFreak | Multi-Way | 9 | 4th July 2003 12:30 AM |
| Page generated in 0.10671 seconds (81.08% PHP - 18.92% MySQL) with 11 queries |
