Specs on drivers anyone?
Old 11th June 2007, 10:03 PM   #1
Keltern is offline Keltern  Norway
Default Specs on drivers anyone?
Does anyone have access to specs on the Dali 606 drivers?
This is all the info written on the magnetlabel:
Tweeter: D26TG-47-06
06 Ohm - 703
Bass/midrange: TC18BG08-12
12 Ohm - 707
The support isn't answering any time soon it seems..
Keltern
Old 12th June 2007, 05:30 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The tweeter number sure looks like Vifa, TC18 is also used by Vifa.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th June 2007, 06:00 AM   #3
phase_accurate is offline phase_accurate
The Dali woofers are definitley made by Vifa.
Charles
Old 12th June 2007, 06:27 AM   #4
Yes, I reckoned they were Vifa..
But I can't seem to find anything about them, so can any of you guys try? Tried searching around, but no luck.. So I was hoping you could give it a try!
Keltern
Old 12th June 2007, 07:32 AM   #5
frugal-phile(tm)
planet10's Avatar
They are likely OEM drivers made specifically for Dali -- only Tymphany & Dali will have the specs.
dave
Old 12th June 2007, 08:00 AM   #6
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Almost all Dali drivers are OEM VIFA drivers, however the D26TG-47-06 tweeter is very similar to the D26TG-35-06 (http://www.tymphany.com/datasheet/printview.php?id=255)
The woofer I'm afraid doesn't have a directly comparable off-the-shelf version.
Old 12th June 2007, 08:27 AM   #7
Typical.. ^^
Is there anyone on this forum that's known for having a connection to Dali?
I don't want to throw these away, cause I'd rather use them in a little DIY speaker.. I have two sets of 606, and one of them are a bit shabby, so I thought I'd make use of the drivers..
But it seems it's hard to get specs on them, so I don't know what to do...
Keltern
Old 12th June 2007, 08:39 AM   #8
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Measure them then. You should anyway if you are making a decent job of the project even if you have manufacturer parameters.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 12th June 2007, 08:50 AM   #9
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
The woofer should be close to this but with a higher impedance curve.
http://www.tymphany.com/datasheet/printview.php?id=290
In Oz we get a PAE 18WG08 which is basically a TC / BC driver.
http://www.digitalmegahouse.com/peer...20speakers.htm
Old 12th June 2007, 10:49 AM   #10
Saturnus's Avatar
Well, I do business with Peter Lyngdorf but I'm not sure he's willing to disclose such information. I can ask at the next oppertune moment though.
Specs on drivers anyone?Hide this!Advertise here!
t/s specs for indian drivers somakmaitra Multi-Way 776 19th August 2013 10:50 AM
TS parameters and specs for these drivers??? Bull Multi-Way 1 9th March 2011 12:15 PM
Matching drivers...beyond the specs smokinghot Multi-Way 4 28th January 2009 10:41 AM
need driver specs for raw Bose drivers Jared Multi-Way 2 18th November 2002 01:44 AM
Copyright ©1999-2017 diyAudio
