Almost all Dali drivers are OEM VIFA drivers, however the D26TG-47-06 tweeter is very similar to the D26TG-35-06 (http://www.tymphany.com/datasheet/printview.php?id=255)
The woofer I'm afraid doesn't have a directly comparable off-the-shelf version.
Typical.. ^^
Is there anyone on this forum that's known for having a connection to Dali?
I don't want to throw these away, cause I'd rather use them in a little DIY speaker.. I have two sets of 606, and one of them are a bit shabby, so I thought I'd make use of the drivers..
But it seems it's hard to get specs on them, so I don't know what to do...
The woofer should be close to this but with a higher impedance curve.
http://www.tymphany.com/datasheet/printview.php?id=290
In Oz we get a PAE 18WG08 which is basically a TC / BC driver.
http://www.digitalmegahouse.com/peerless audio speakers.htm
Keltern said:Is there anyone on this forum that's known for having a connection to Dali?
Well, I do business with Peter Lyngdorf but I'm not sure he's willing to disclose such information. I can ask at the next oppertune moment though.
richie00boy said:Measure them then. You should anyway if you are making a decent job of the project even if you have manufacturer parameters.
Well, I don't know how decent it'll be, as I haven't built speakers before.. But I'll try to make the best of it!
Sounds good! I just hope I'll be able to make use of them.. It'd be a shame to throw them away just because someone thinks such info should remain a secret.. They're not in production anymore, so I don't see the big deal! But then again, it could just be me!
- Specs on drivers anyone?
