My multimeter will measure ohms to one-tenth precision. I can't imagine that is sufficient to obtain measurements for valid T/S calculations. Can anyone recommend a multimeter (brand/model) that will work best? Preferably handheld, under $100 if possible.
Mike "Twelve." --Dr. Nikolai Zubritsky |
#3 |
My current one is digital auto-ranging handheld from Radio Shack but is limited to .1 precision when used to measure ohms. I'm hoping someone can provide a suggestion for one to replace that with.
#5 |
measuring frequency and amplitude at low frequencies is a far bigger problem. Both my handhelds cannot measure amplitude accurately due to the way they sample the waveform. My bench DMM is superb at all frequencies and a single push switch also measures the frequency (well).
regards Andrew T. |
#6 |
Liasom,
Remember that just because your handheld DMM has a resolution of 0.1 ohms doesn't mean that is has an accuracy of 0.1 ohms. Most meters with a resolution of 0.1 ohms will have an accuracy of +/-0.1 ohms +/-3% of the full scale range. A decent handheld meter with a resolution of 0.01 ohms, is a Fluke 76. It is a true RMS meter also. You have to calibrate it for the 0.01 ohm resolution everytime you change functions or power it up, but it will do it. I think you can get it for around $130.
Jack Hidley ACS |
#7 |
The most accurate measurement can be done using the 4-wire method. Drive 100 mA DC current through the speaker. You can connect the multimeter in series and measure the current precisely. Then measure the DC voltage across the speaker terminals with the same or another multimeter, and calculate. This way you don't include the multimeter probe wire resistance in the measurement. Also it is more realistic, because the speaker coil resistance is temperature dependent. Driving 100 mA through the coil approximates normal operating conditions.
#8 |
Thanks!
That said - I only have one project I want to do for the near future that will be stereo loudspeakers with a mono sub to augment the low frequencies. My budget is ~$1000 for the loudspeaker system. I plan to build the stereo pair from an existing design (Zaph's L18 as sealed version). The T/S measurements I need are for the sub driver (NHT 1259 I purchased used). My feeling is I don't need to spend $350-400 testing a $150 woofer that I bought for $100. I have a some engineer types as friends. Maybe I can talk one of them into helping if I buy the beer... ...and, of course, some more beer when I need to test my crossover components to insure they are within tolerances.Mike
#9 | |
perhabs you have to substract the wire resistance there is really no need to buy new equipment, if you don't know what your existing dmm is capable of regards |
#10 | |
Mike
| Measuring resistance while circuit is turned on | HiFiNutNut | Everything Else | 5 | 12th January 2009 02:06 AM |
| parameter conversion | memphissound | Multi-Way | 1 | 28th July 2008 07:49 PM |
| New Pentode measuring resistance between grids G2 and G3 any idea? | MRupp | Tubes / Valves | 5 | 5th January 2008 06:24 PM |
| Req. What does this parameter mean? | stigla | Tubes / Valves | 9 | 7th March 2003 07:40 AM |
| Page generated in 0.09220 seconds (85.88% PHP - 14.12% MySQL) with 10 queries |
