Old 10th June 2007, 06:12 PM   #1
GOWA is offline GOWA  Canada
GOWA's Avatar
Default Lcy 130 Ribbon Help
Does anyone have the TS Parameters for the LCY 130 RIBBON TWEETER? I am going to use X-OVER PRO to try a X-Over design.
I contacted Ying Tai Trading Co. through their website at http://www.lcy.com.hk/ with no luck. All other manufacturers have the Driver specs available on their websites but not LCY. The only infomation that they list is:
Frequency Response : 1.8KHz-60KHz
Sensitivity : 92dB / 2.83V / 1M
Nominal Impedance : 8Ù
Magnet Type: Neodymium magnet
Ribbon Effective Area : 740mm2
Ribbon Thickness : 0.006mm
Nominal Power Handling : 150W
I know that John Krutke ( Zaph) has tested this particular tweeter, so John if you are out there, can you help with this matter?
Website
Old 10th June 2007, 06:53 PM   #2
E-speaker also sells this tweeter, you can try to mail them.
E-speakers
To ESL or to Ribbon? PhaseLockLoopy Planars & Exotics 83 5th August 2011 12:01 AM
DIY ribbon mic rafafredd Analogue Source 6 14th September 2009 09:37 AM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 08:50 AM
ESL, Ribbon THD Mor den Siur Planars & Exotics 26 2nd March 2009 10:09 PM
to ESL or to ribbon? lekguan Planars & Exotics 3 4th December 2008 02:53 PM
Page generated in 0.06436 seconds (67.95% PHP - 32.05% MySQL) with 10 queries
