Benefit of separate mid boxes?
In a three way, other things being equal (yes, in some ways they will be not), if the bass is vented: how much SQ benefit is there putting the mid in a separate sealed box, within the bass box?
With drivers I have, a sealed 6 litre mid box within the bass box, results in a Q of 0.55; or the mids mid in the 38 litre vented bass box, results in a Q of 0.497. (The effect on bass response can easily be offset by varying port tuning).
Hi Rick57,
putting the mid in separate box have plenty of advantages:
1. The bass driver didn't affect mid operation too much (and vice versa).
2. Resulting sound is cleaner.
3. Since interaction between woofer and mid is minimal, calculation will be easier.
4. Mid and woofer can have different tuning (vented, sealed, free air, etc )
5. SQ benefit is big, and worth it IMO, practically all hi end gear do this at their upper class product for exactly the same reason.
disadvantages are:
1. more cost for commercial speaker is not good, not much added cost for DIY.
2. box is harder to construct and will be heavier , which is not a big problem for DIY.
You don't have to put the mid box inside the woofer box though.
How is it going in Melbourne ? are you using passive or active XO ?
for my lowly advice, please feel free to send some four and twenty meat pies ;)
Hartono
Hi Hartono,
~ I gather you’ve had the pleasure of Melbourne’s Four and Twenty pies? :eek:
Thanks for your advice, I suspected putting the mids in a separate box has advantages.
In this case I will put the mid box inside the woofer box, as I came across a very nicely made woofer box that I don’t have the box skills or woods to match in a separate box. The outputs don’t match and I have an ok 6 channel amp: I’ll go active XO.
Do the thinking/ philosophies about box building, eg mass & bracing, apply to mid boxes inside woofer boxes?
thanks
Hi Rick57,
" ~ I gather you’ve had the pleasure of Melbourne’s Four and Twenty pies? "
Yummy..............
"Do the thinking/ philosophies about box building, eg mass & bracing, apply to mid boxes inside woofer boxes? "
Yes it would be the same, except you don't have to do any finishing :D . You might like to browse a bit on Diyaudio.com for building and bracing box, plenty of good information, as my experience in woodworking is limited I can not offer much handy information.
wish you good luck, with your project !!
Hartono
A good approach to a mid enclosure is a terminated transmission line. Just build it long and tapered, as large as is reasonable, and stuff it full of polyfill. The idea is to kill the back wave.
If you were to have the mid in the same enclosure space as the woofer.... it's bad. As the woofer pressurizes the box, it pushes the mid outwards. This causes unwanted excursion which will cause harmonic and intermodulation distortion. Even if the box for the mid doesn't go to any heroic lengths to prevent internal reflection if the sound it radiates into its own box, it's still better than leaving it exposed to the effects of the woofer.
Thanks Joe,
I don’t have space here for a transmission line
Wrt mid boxes inside woofer boxes
That’s a big advantage to me right now ;)
I was thinking of low mass mid boxes; surrounded by high mass eg lead lining, between the mid boxes and the woofer boxes: would the high mass lead between the boxes be useful?
Cheers
gee, I thought that all mids needed seperate boxes??? otherwise the pressure from the bass unit could-at worst- blow the mid.
Maybe I've misunderstood the question ar at least have been sold a whopper (not some sort of meat pie:) ).
Tweeters of course are (usually) always sealed so won't suffer from the bass pressure.
If I got that wrong I'd love someone to explain.
rick57 said:
Thanks Joe,
Cheers
What do you hope to accomplish with this method? The first concern would be that the mid enclosure keep any air pressure from the woofers from modulating the mid. This would best be achieved with a really stiff box. Considering how small the mid box probably needs to be, single layer 0.75 inch MDF or plywood with a single brace across it would be more than adequate. Constrained layer damping, in my opinion, would be overkill for the task at hand.
The second concern with the mid enclosure is to minimize the ill effects of the rear wave firing into a box. The best method after a transmission line (you might be surprised how small these can be- check out B&W) would be a "golden ratio" shaped box.
Having separate boxes is a bit like having double-glazed glass instead of a really thick single layer.
As long as you know what you're doing in terms of creating a sound barrier that prevents crosstalk between the bass and midrange, then the final design should be determined by other considerations like: baffle diffraction,...
What if you want to be able to upgrade the midrange without changing the woofer? Or adjust the time alignment to suit the furniture?
Rick the benefit is huge as long as the mid is not cramped into too small of an enclosure.
THe midrange is actually the most important driver in a three way system unless it is high passed at a very high frequency like some of the older very cheap commercial systems. But in those systems you really had the woofer doing most of the midrange activites so I will not consider them.
Also, if you want the best midrange sound in a sealed enclosure make sure it is critically damped. If you isolate the midrange in a high Q sub enclosure the sound will not be that good.
You should think of the midrange as a full range driver that needs the highest of fidelity and isolated as much as possible both acoustically and physically from the other drivers.
The midrange should ideally cover the 80-3000 Hz range with perfect fidelity which is where nearly all the fundemental tones in music and voice are.
If this area is not handled right the speaker can never be more than mediocre sounding no matter how good the bass and high end are.
I agree separate boxes are preferable, but just want a system to do quickly, and it won’t be my main system.
I came across some beautifully built veneered MDF boxes, I know ply is better and will use ply for the Q = 0.55 sealed mid box (with B&C drivers) .
To minimize the ill effects of the rear wave and transmission of vibration, I will follow the Linkwitz style neoprene driver mounting, and eg Planet10 school of 'air damping'.
I agree a really stiff box is important. I had in mind a plywood box. Certainly not going as far as constrained layer damping. 0.75 inch or thinner, the idea being the mid box itself has low mass for minimal energy storage (Linkwitz school).
Any suggestions on how best to build it?
- presumably do five sides of ply (sharing only the front baffle), rather than at the other extreme - just two sides (sharing also the sides and top).
As I won’t be building a separate box, I thought a high mass ‘barrier’ would add to the "insulation" from the big 12 " woofer. Should there also be a “lining” around the outside of the (enclosed) mid box?
Cheers
Rick,
As long as mid is in a Q .5 sub enclosure you should get good results. Even if it is inside the main box. However make sure the sub enclosure is fully stuffed with dacron and acoustic foam. You have to deal with the standing waves too. But this is easy. Good luck.
Rick,
Sorry for the confusion on my last post. The main woofer enclosure even though vented will benefit tremendiously if it is stuffed to some degree. You can line all the walls with acoustic foam and stuff the box more lightly with dacron than you would the mid enclosure.
However, leave the area near the port free of stuffing. You have to experiment a little with the stuffing to get the best amount. Often in a vented design it works well to stuff only half of the cabinet around where the woofer is and leave the side with the vent free of stuffing. But I would use acoustic foam on all walls.
In the mid enclosure a Q of .55 is pretty good and after you stuff it with dacron the Q will be even a little lower. THe mid enclosure will probably work best with a little more stuffing than the woofer since too much stuffing in the woofer cabinet will kill the bass response. In the mid cabinet you don't care if you kill bass response. You just want the cleanest, fastest, most well damped sound. But just the right amount will improve the sound a lot.
AMV8 said:
rick57
I find that the main advantage of a separate mid or mid/treble box is that it is of limited size and can be made very rigid. A rigid midrange cabinet pays benefit in terms of allowing clear midrange and voices.
Don
I have to agree with this completely, but sometimes the design requires an integrated approach. If you want the last word in good sound a seperate enclosure is the best but you can still get good results with the proper midrange isolation chamber inside the main woofer enclosure.
