#2 |
http://www.neeper-acoustics.com/pics/tech_cabinet.jpg
I think this one is also a cool design http://www.neeper-acoustics.com/tech.html |
#3 | |
#4 |
You can also use a table saw or router to make "slits?" in a board and then you will be able to bend it. There is calculations that will allow you to have an appropriate distance between the "slits?" depending on the radius of the bend. The same principle as that used in the "bendable MDF" sheets that sells for serious money. Those I've only seen in 9 mm so far, but there might be thicker ones out there.
| Cabinet design | jwhit67 | Multi-Way | 4 | 14th February 2008 03:46 PM |
| HPD315 Cabinet Design | inrank | Multi-Way | 6 | 19th March 2007 04:05 PM |
| how's this for cabinet design? | legendaryfrog | Full Range | 13 | 20th November 2006 10:23 PM |
| Page generated in 0.07048 seconds (76.49% PHP - 23.51% MySQL) with 10 queries |
