The personal planars
Old 27th January 2003, 06:02 PM   #21
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
well, i just bought the plans, gonna go out and get the supplies... looks like building them will be a bit more difficult than i expected, but nothing TOO hard... will let everyone know how it goes
Old 27th January 2003, 07:33 PM   #22
Pjotr is offline Pjotr
Pjotr's Avatar
Good luck finding the skilled woodworker from the material list LOL
For $10 this is great fun. For the foil I will use 20 mill thick mylar foil that is coated with a heat sensitive glue. It is intended for model aeroplanes. Just a tip
This will gonna be a long thread on the best sounding film.
Old 27th January 2003, 08:33 PM   #23
Marmaduke is offline Marmaduke
Send a message via AIM to Marmaduke
With creativity this could likely be an under $10 project (or even less).
Thanks, this is what i was asking for. I think i am going to buy a password and try to make a pair of these.
Thanks for the info.
Old 27th January 2003, 09:09 PM   #24
Topgun is offline Topgun  Canada
Topgun's Avatar
Default What kind of plans are they?
Just wondering what kind of plans they are? If they are easy to read and to understand for a beginer. I know it's only ten bucks but i don't want to thow that away on a plan that is unorganized and poorly written.
Old 27th January 2003, 11:50 PM   #25
cowanrg's Avatar
the plans could be a bit better... you need to kind of guess a lot, and add in your own experience. not really 100% beginner material.
and im already having a problem getting the drivers necessary. i got ALL the other parts at a hardware store for $35. (i dont have ANYTHING sitting around, i live in an apartment, i only get whats needed for each project.)
i just need the drivers now, so i would call it a $50 project for the pair.
Old 28th January 2003, 01:16 AM   #26
Jared is online now Jared
Send a message via AIM to Jared
how would these compare to a diy electrostatic speaker?
Old 28th January 2003, 01:27 AM   #27
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
What kind of drivers does it call for?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2003, 05:33 AM   #28
cowanrg's Avatar
well, i dont wanna say becuase i think it would give it away, ill send you an email. maybe you can help me...
dave
Old 28th January 2003, 02:48 PM   #29
Topgun's Avatar
Would 3" car speakers work? I have a ton of these at home and i want to put them to some use.
Old 1st February 2003, 02:15 AM   #30
DrDave is offline DrDave  Canada
The biggest cost will probably be the drivers. You need ones with a vented pole piece. I got some JBL car speakers that were more expensive than needed. I think almost anything would do.
Outer diameter has to fit inside a 4" plastic drain coupling.
For me, the hardest part to find was a tweeter diaphragm to seal the pole piece hole.
The other stuff you need is cheap. Plastic drain coupling, aluminium rod, bondo (I used wood instead), some wood scraps (I laminated tongue depressors), plastic heat shrink storm window plastic file, double sided tape, some sealant and glue.
The only tools I used were a drill and a dremel to rout the wood piece. Steve's bondo method would be easier.
The personal planarsHide this!Advertise here!
Personal Planars. tade Planars & Exotics 19 28th March 2010 02:11 AM
Where can aussies get cheap planars ? gainphile Multi-Way 0 8th April 2008 04:42 AM
Induction planars APi Planars & Exotics 12 6th August 2007 05:53 PM
B&G Planars Dr Mewlon Planars & Exotics 6 29th April 2004 12:11 PM
q's about planars duke of dorkdom Planars & Exotics 1 28th October 2001 10:07 PM
