#11 |
That's the idea, you can easily afford to fry a pair so get 2 in case that happens when you remove the "crossover" they come with. These must be the newer Audax drivers that are manufactured in China, there's no way a French made Audax would sell for such a low price. This being said there's probably no difference in quality.
#12 |
I'll send you are pair of these if you want them. 4 ohm, 12 db hi & lo at 2600 Hz - that would help smooth out the woofer where it starts to get ragged, and offer better protection for the tweeter than the single cap. 5.5" x 2" X 1" - I've soldered leads onto them. You'd have to mount them somewhere, but hey that's part of the fun of it.
Soft Dome |
#13 |
That might work perfectly. PM me with how much you want for them....
| Easiest way to cut PCB's? | Dr.H | Parts | 38 | 25th May 2010 12:51 PM |
| Easiest Line Level Amp ? | Modelworks | Analog Line Level | 2 | 11th February 2006 10:16 AM |
| cleanest/ easiest EQ | rick57 | Digital Source | 15 | 1st July 2005 04:52 PM |
| Easiest way to reduce rails. | K-amps | Solid State | 17 | 11th February 2004 08:55 AM |
| Bets and easiest type of amp? | T_Lav | Solid State | 4 | 13th September 2001 05:35 AM |
| Page generated in 0.08115 seconds (73.76% PHP - 26.24% MySQL) with 11 queries |
