Old 5th June 2007, 09:58 PM   #1
Default Help with a P-Audio driver
Hello to everybody!
I was wondering if somebody could help me with the simulation of a TQWT box with the P-Audio C12-300Mb with these T/s:
Power Handling Capacity 300 W rms
Power Handling Capacity 600 W rms ( uncliped musical program )
Sensitivity 2.83 V, 1M - 97.4 dB
Effective Piston Diameter 255 mm (10.0 inch)
Voice Coil Diameter 75.66 mm (3.0 inch)
Resonance Frequency FS 48.4 Hz
DC Resistance Re 5.4 Ohm
Mechanical Q Factor Qms 7.445
Electrical Q Factor Qes 0.307
Total Q Factor Qts 0.295
BL Factor 14.86 T x m
Effective Moving Mass Mms 41.28 g
Equivalent Cas air load Vas 96.60 liters
Effettive piston area Sd 0.0510 m
Voice - coil inductance@ 1KHz Le 1k 0.88 mH
Half -space efficiency Eff 3.45 %
Airgap Height Hag 12.0 mm
Voice coil Height Hvc 18.5 mm
Voice Coil Over - Hung Xmax 3.3 mm
A drawing with the box inside would help me a lot too.
Thanks for your time!
Old 9th June 2007, 07:20 AM   #2
Nobody who can help me?
Old 9th June 2007, 08:21 AM   #3
Send a message via ICQ to Mikael Abdellah Send a message via MSN to Mikael Abdellah
have you tried winisd? it is a free and very useful program for simulating different boxes. if you can't figure it out i can help with some suggestions for box later, but you really should try it yoursefl first. drop me a message if you still need help.
http://www.linearteam.org/download/w...winisdbeta.exe
Old 9th June 2007, 09:36 AM   #4
Hi!
Thanks for the reply.
I know to use WinIsd, but I don't want a bass-reflex box, I would like to know some dimensions for a TQWT box.
Thanks!
P.Audio / Jarcar OB driver choice broughd Multi-Way 8 5th March 2008 11:42 AM
who has the best audio driver prorms Solid State 11 29th May 2006 10:36 AM
Looking for a good NPN audio driver for my power amp. Progg70 Solid State 16 26th October 2005 01:30 PM
New to DIY audio: in search of driver Matte Multi-Way 2 15th February 2005 09:35 AM
Mosfet audio driver mik Chip Amps 11 28th October 2003 04:14 PM
Page generated in 0.07928 seconds (62.53% PHP - 37.47% MySQL) with 10 queries
