Explain the push-push thing to me
Old 25th January 2003, 05:27 PM   #11
MJK is offline MJK  United States
Dave (aka kneadle),
If you go to my site and look under General Speaker Articles, you will find a short write up explaining how to model two drivers in one box using my MathCad worksheets. It explains which T/S parameters to adjust to model wiring the drivers in series or in parallel. An example is provided which should allow you to run any of the worksheets, with an equivalent driver modeled, simulating the two driver configuration.
Old 25th January 2003, 05:49 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by kneadle
Why must the cross section double? That's the part I don't get. I'm not even sure what the PRECISE meaning of "cross section" is.
The cross-section is doubled for 2 drivers as compared to one because the Vas doubles. With a fixed line length this just happens to double the volume.
If you consider the line to be a pipe of length l, width x, and breadth y (assuming a rectangular section here). Then volume is l*x*y and the cross section is x*y.
Another way to look at it is in the classical sense. A line is defined as a function of the driver's Sd. It starts at 3 Sd and ends at 1 Sd for example. If we use 2 drivers instead of 1 then Sd is doubled and the thus the line cross-section is doubled.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th January 2003, 05:49 PM   #13
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
Default Excellent!
Thanks Halo, Planet10, MJK, Ryosho and all others,
I am very well-informed, now. In due time I will propose a design solution for this TL problem.
In my other post I mentioned that I wanted a challenging little project for four MCMs, and now my cup runneth over with challenge.
Dave
PS--where can I learn how to make a plug for the MCM 15-1855?
Old 25th January 2003, 06:08 PM   #14
frugal-phile(tm)
planet10's Avatar
Here is a drawing i did for 1855 phase plugs (made from anything you can put in a lathe). The green or blue lines are the ones to follow, the red was for reference. The grid is a 1/2 mm i believe.
If you imbed a steel washer in the base it will stick to the pole piece for temporary attachment.
I haven't actually built these yet.
dave
Explain the push-push thing to meHide this!Advertise here!
Please Explain difference Mono vs Push Pull vs Single End etc hdlcx2 Tubes / Valves 11 3rd August 2008 02:27 AM
help tuning push-push ApexJr super 8 woofer planet10 Subwoofers 22 28th September 2005 04:00 AM
Photos - My first T-Line Push-Push Subwoofer :) Xmax BR Subwoofers 6 23rd June 2005 08:17 PM
damaged cone usage (push push?) kneadle Multi-Way 24 27th January 2003 04:51 PM
Copyright ©1999-2017 diyAudio
