Well I have a rather large set of speakers that I am working on. They have about 100sq feet of interior surface. I was looking for a long time for sound deadening material, and finally went to Lowe's. I read the labels on all the cans of various coatings. One of my major concerns was having any product with high VOCs in them. I don't want drivers to come unglued do to fumes. I chose rubberized latex driveway sealer after doing a lot of reading of labels. I dipped a piece of MDF in the stuff. I left it on as heavy as I could to try to get it to fail by peeling or cracking. After 2 days of drying I was able to scrap the coating off the MDF. It does bond well, but I used a bit of elbow grease to get it off. I wanted to see if there was any problem with wood swelling or softening. No problems. Second test. Picked up a hammer, and struck both ends of the MDF. There was a definite ring to the end with no coating, and the treated end sounded nice and dead. The cost of a 5 gal bucket was $25! works great. I applied a thin coat today as a tack coat. I have painted for many years, and know to put on a thin coat at first, then build up the fallowing coats.
Here is a link to my project. http://www.polkaudio.com/forums/showthread.php?t=53273 You have to do some scrolling to see the progress pictures, but I believe it is worth a read, and I like to get feed back on my ideas. Thanks Ben |
#2 |
66 views, and not one reply?
Has anyone ever tried this approach? |
#3 |
I haven't tried it in speaker cabinets but if it's like the stuff used to reseal flat roofs I've used it quite a bit for its intended purpose. It's water based and definitely doesn't give off fumes and yet it dries to a rubber-like substance, so yes it could be useful for cabinet damping.
If I was taking on a DIY speaker project I would try something like that, or try to find something that sets to rubber in the absence of air so that I could lay panels of hardboard on top, that ought to damp really well. |
#5 |
Thanks for the link. I have turned into an audio junkie about six months ago. I spend an average of 3 hours a night on reading!
Ben |
#6 |
The article covers a range of materials for loudspeaker cabinets. One of the many interesting points it discovered is that doubling cabinet wall thickness has relatively little effect on wall resonance - you just have to use twice as much damping material.
Good luck with the rest of the reading - there is some good stuff out there. Some of the classic loudspeaker books from the 50s and 60s have hardly dated and contain priceless material. |
#7 |
I have David Weems book on loud speakers design. The main reason I posted this is many people are buying very expensive acoustic dampening material. I bought the rubberized latex driveway sealer for $25 for 5 gallons. It works great. I dipped a piece of MDF in the bucket fully knowing that heavy first coats typically fail either by cracking or peeling. To my surprise I did not have either issue with the test piece. I hit the treated end with a hammer, and I heard thud thud. I hit the other end of the MDF, and I heard a distinct ring. I have had quite a bit of help here electronically. I just wanted to share this with you guys. I highly recommend if you are using any sort of coating to apply a light "tack coat" first, and then build it up. The last coat I used as the adhesive for the poly batting. It worked out fantastic.
Ben |
| Barium Sound Deadening - How Effective Is It? | villeneuve | Multi-Way | 1 | 10th August 2009 03:13 PM |
| sound deadening my car. some advice please | therich | Car Audio | 7 | 29th March 2009 08:58 AM |
| Sound deadening for walls & ceiling | Mr Pookie | Everything Else | 3 | 6th January 2005 04:23 AM |
| Sound deadening mat installation Q's | curtis73 | Car Audio | 2 | 25th October 2004 05:26 AM |
| sound deadening a bedroom?? need ideas.. lol | SkinnyBoy | Everything Else | 45 | 24th January 2004 02:28 PM |
| Page generated in 0.09682 seconds (77.28% PHP - 22.72% MySQL) with 10 queries |
