what is the best type of paint to use for spray guns
i would like something on the lines of black up to high gloss look
and i saw some ash black for fence but it was £17 and well bit to much for testing really
i don't know all the names types so if brands be better or a url thanks
I have used a low pressure spray gun with my air compressor, it's an internal mix type so you can adjust the spray pattern and pressure. It will spray anything from flat primer to high gloss enamels. They run anywhere from $20-$50 US.
An HVLP type would work as well. These are used a lot for automotive painting so it should lay even lacquer on pretty smooth. Be sure you do it in a dust free enclosed environment, and wear a mask
