Old 25th January 2003, 07:33 AM   #21
frugal-phile(tm)
planet10's Avatar
Default phase plugs
Shoog has the right idea.
These are a nice little driver. They need a bit of puzzlecoat on the front or back (or both) to damp some HF ringing. (after my experiments with them, a fellow i corresponded with tried a large number of cone damping materials and puzzlecoat worked best).
Picture from my 1st MCM 1855 project
Do a dustcap-ectomy on a 2nd driver. That will make them a bit better. Then add a phase plug to fill the hole (to stop the soup can resonance in the cyclindrical cavity). A nicely shaped wooden or plastic phase plug can give additional benefits but a cyclinder of wool-felt works too.
Then go ahead with the push-push. Then you can rotate them a 180 degrees and compare no cap to capped.
The 1st thing i did when i got my batch of these was to remove the dustcap (my lab is littered with dustcapless drivers)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th January 2003, 09:17 AM   #22
Just saw a post on a German forum where somebody claimed the leakage in drivers with phase plug and a basket that is open behind the spider (e.g. Excel) was so big that the Q of any sealed design became very poor and that in a ported design you could acutally hear the air going through the gap between VC former and phase plug.
Old 27th January 2003, 12:05 PM   #23
kneadle is offline kneadle  United States
kneadle's Avatar
Send a message via AIM to kneadle
I have two options, then:
1) Let Planet10 do it first and tell me how it goes.
2) ask, "is a phase plug permanent, or can I try it to see what it does?"
Thanks,
Dave
Old 27th January 2003, 04:49 PM   #24
frugal-phile(tm)
planet10's Avatar
You might wait a while
If you use the steel washer method, you can install & remove the phase plug as often as you need -- just be gentle and the plug can't have too high a mass.
dave
Old 27th January 2003, 04:51 PM   #25
frugal-phile(tm)
planet10's Avatar
You also have to worry about leakage thru the surrounds (cloth surrounds) and retransmission of yukky noise from vented pole-pieces.
Another reason to look at low pressure enclosures (open baffles, TLs, Voigt pipes, aperiodic boxes)
dave
Push - push subwoofer spacing. Ap Subwoofers 23 4th September 2007 07:09 PM
help tuning push-push ApexJr super 8 woofer planet10 Subwoofers 22 28th September 2005 04:00 AM
Photos - My first T-Line Push-Push Subwoofer :) Xmax BR Subwoofers 6 23rd June 2005 08:17 PM
Questions on push-push subs... Schaef Subwoofers 39 20th November 2004 02:46 AM
Explain the push-push thing to me kneadle Multi-Way 13 25th January 2003 06:08 PM
Copyright ©1999-2013 diyAudio
