Hey guys, my names David. Im 17 and just recently joined HT Guide and have been interested in Hi-Fi for many years. It wasnt until recently until I heard a pair(well actually 4) B&O Beolab 5's. That was beyond amazing.
Im interested in building a set of front floor standing speakers (full range) and need a bit of help. I know a fair bit, but my knowledge is still limited. How many drivers should I be looking at (3 or use 4 for low and high pass) Type of Crossover(was thinking of linkwitz-riley, but then again I know little about crossovers) Finally, brand of drivers... I want a good quality set without spending huge amounts.Also where to get them(I live in australia). Price range: have no idea what drivers cost(quality ones that is) People said drivers like usher, but these are asian drivers, have no idea of how good they are. I was thinking something like Polk etc. What do you think? Thanks guys.. |
#2 |
Seas drivers are available down under so I suggest taking a look at this, you would need to find a source for a similar horn lens : http://www.zaphaudio.com/Waveguidetmm.html |
#3 |
You might try the PE website of projects:
http://www.partsexpress.com/projectshowcase/index.cfm This floor standing model is terrific and the designer is a very qualified Electrical Engineer: http://www.partsexpress.com/projects...trix/index.cfm Zarathu
Youth is wasted on the young. |
#4 |
thanks sreten, I had actually decided on going Seas but didnt update my post. I was pushed away from them in my other post(different forum) and told to go for Dayton RS 3-way.
How many drivers should I go for. Normal 3 way, or have 1 tweeter, 2 mid and 2 bass? Also, I thought it was a bit strange with the seas excel, their tweeter is 2000-20000hz. Seems like to much of a stretch, wouldnt a mid from the prestige range be better to add to the tweeter? |
#5 |
I think B&O use digital room correction in their speakers, so you'll probably have a very hard time equalling that.
If you're just starting off, I definitely wouldn't use any more than 3 different driver sizes: 2-ways are a compromise: they're not really "full-range" unless you put a lot of extra work into building TQWP boxes, vented boxes, or you add a sub. 3-ways seem to have more potential, but you have to design a more complex crossover and more things can go wrong. As for a 4-way design, I don't see any technical reason why it should be necessary.
Lech |
#6 |
Kirbs,
Whatever you use, you must remember that the passive crossovers are not interchangable. If you change the speaker in a design that already has a schematic for the crossover, then you CANNOT USE THAT CROSSOVER. Zarathu
#7 |
http://www.rjbaudio.com/projects.html
http://www.zaphaudio.com/ http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://www.humblehomemadehifi.com/ Hi, You should be able to find something suitable from the above. possibly : http://www.rjbaudio.com/AlpheusMkII/alpheusmkii.html |
#8 |
I second sreten's suggestion. Alpheus Mk II uses relatively inexpensive yet excellent drivers. Looks very appropriate for a first-time DIYer who wants to do a 3-Way.
#9 | |
#10 |
Solen.ca still lists it in the catalogue. They might have them still available.
But at $70 retail CDN each, this system is getting out of budget for me. http://www.solen.ca/pee.htm |
| First time build - looking for advice. | photon | Subwoofers | 3 | 12th March 2009 07:57 AM |
| First time advice | Craig405 | Multi-Way | 12 | 13th April 2008 06:10 PM |
| K-12G First Time Build | TubesRule6656 | Tubes / Valves | 7 | 29th April 2007 07:17 PM |
| Time to build the F3 | auriontoledo | Pass Labs | 18 | 18th January 2006 02:39 PM |
| Page generated in 0.12105 seconds (84.11% PHP - 15.89% MySQL) with 10 queries |
