Did the search here and google search. Has anyone designed a baffle step for an rs52?
#2 |
You probably did not find anything because the issues are far more complex than your simple question implies. Depends on the particular speaker design. |
#3 |
you talking about the klipch RS52?
#4 |
#5 | |
#6 |
It is for the Dayton. It is for auto application.
#7 |
Hi, In a car you generally do not need baffle step compensation,
#8 | |
Does your head unit have any EQ? If you've tried turning up the bass to these 5" speakers then you'll probably already know what I mean. Could you squeeze bigger/better speakers in? Considered a small sub? |
#9 |
The system is not put together yet. Based on what I have read the RS52 has a 12db peak at 13000hz. I want to run the RS52 to 6k hz if possible so I am concerned about the peak. My active cx is 12db.
#10 |
http://www.zaphaudio.com/smalltest/
Hi, the above has the measurements. You should repost with notch filter / trap filter instead baffle step in your title. http://www.partsexpress.com/projects.../crossover.cfm There are probably quite a few other examples around. |
| Does open baffle suffer from baffle step? | 454Casull | Multi-Way | 15 | 19th May 2012 03:12 PM |
| baffle Step | rgrayton | Full Range | 33 | 4th December 2004 11:16 PM |
| Baffle Step + Sub | Aural Dan | Multi-Way | 7 | 9th October 2004 08:23 PM |
| How to calculate baffle step? | henriksommer | Multi-Way | 11 | 7th May 2004 07:16 AM |
| baffle step help. | AudioGeek | Multi-Way | 3 | 10th February 2004 11:02 AM |
| Page generated in 0.10197 seconds (80.18% PHP - 19.82% MySQL) with 10 queries |
