passive crossower help needed
Old 29th May 2007, 09:59 PM   #1
smokingmachine is offline smokingmachine  Slovenia
Default passive crossower help needed
hy!
here are the pa speakers i intend to use in pa boxes
bass:
http://www.bcspeakers.com/download/p...F/more/147.pdf
horn:
http://www.bcspeakers.com/download/p...F/more/151.pdf
what would be the best crossower frequency?colud be just one crossower frequency?
and what other frequency network should i use?
attenuator for horn will be needed i think(-4 dB attenuation), but which others would be usefull?
remind that the bass will be 4 ohm, horn 8 ohm
the PA box will be bassreflex type
i need help on this project
this box will be connected to quasi`s n-mosfet amplifier with 450W rms at 4 ohm load
Old 30th May 2007, 04:13 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
It seems the woofer is usually used up to 700Hz and the tweeter has a recommended minimum 1.5K 2nd order. So that means you have to cross the woofer over higher than you want. For PA use it might not be too bad. If you have the chance to bi-amp, that might work the best.
planet10 needs your help:
Let's help Ruth and Dave
Old 30th May 2007, 05:14 PM   #3
R.I.P.
Seems to me you need an electrically assymetric crossover.
Fairly standard selection of crossover point for the tweeter, given
its impedance peak you should compensate this for high power
handling, see http://www.mhsoft.nl/SeriesNotchfilter.asp
The 12" you rolloff early, say with a single inductor such that the peak
is flattened and becomes the roll off / crossover point of the driver.
sreten.
passive crossower help neededHide this!Advertise here!
Louadspeaker crossower - digi in/out - no analouge TNT Digital Line Level 5 25th December 2010 03:08 PM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 01:14 AM
dB loss by using passive crossovers? Active vs Passive and 1st vs 4th order Hybrid fourdoor Multi-Way 3 11th July 2004 10:16 PM
Crossower suggestion Zeljko Multi-Way 4 28th January 2004 05:24 PM
Copyright ©1999-2017 diyAudio
