so Ive been having an itch lately to build a pair of budget speakers. At the moment I'm running a pair of KEF Q15's off a Denon DRA 775RD. I love the combo, but obviously it doesnt get loud enough or have any real low end.
So I've been looking at doing some 2 way towers. Ive been searching all through the madisound catalog looking at frequency graphs, fs's, etc trying to find a good pair of mids/tweets. What I've settled on are: tweets: K1's ($8.55 each) the mids/midbass: F6's ($45.65 each). Was wondering how opinions on this combo would be. I would like to port the mids and tune to 40ish or so. Would this sacrifice the midrange? These are a bit large but I know that large speakers can still produce pretty impressive midrange. Also...would these be ideal for an 8th ordered elliptical crossover? that would be to much fun.... thanks, Jeff |
#2 |
Did it Himself
I don't know what those K6 are, but if you are finding the Q15's not loud or deep enough then you need to be looking at 8 inch drivers at the very minimum.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Hmmm........
8th ordered elliptical filters are fun ? Do you know what this actually means ? The F6 is a decent driver, see here : http://www.zaphaudio.com/6.5test/ Good for a compact sealed box, not so good for a large vented box. The K1 (or SD1.1) is also OK, see here : http://www.zaphaudio.com/tweetermishmash/ How to design them : http://www.rjbaudio.com/Audiofiles/FRDtools.html If you have lots of juice and want serious bass : http://www.humblehomemadehifi.com/Extremon.html or http://www.rjbaudio.com/Extremis/extremis.html |
#4 | |
#5 |
Did it Himself
Well then you need to go 3-way.
#6 | |
well I have been into car audio for a while, and so yes I do know what elliptical is. I collectively have over 15,000 posts on other audio forums, so its nothing new to me. Just growing up and getting into home audio more now. So for the budget I setup above, what would you recommend just using a 2nd or 3rd ordered crossover? thanks |
#7 |
Hmmm........
15,000 posts ? really. I pointlessly got involved in one of your threads. I'm not being patronising, not many understand Cauer filters full stop. I'd recommend using the FRD tools. Normally your target would be 4th order L/R acoustic at the c/o point, but with some added assymetry to account for driver offset. Typically this can be achieved using 2nd or 3rd order electrical filters. c/o selection depends on the driver responses and controlling the distortion products of the drivers, there are no simple rules. But as a primer you should familiarise yourself with the info here : http://www.rjbaudio.com/projects.html http://www.zaphaudio.com/ http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://www.humblehomemadehifi.com/ will teach you more than 15,000 conflicting posts ever could .... |
#8 |
Shown is the F6 driver in a 10L sealed box and 32 litres vented. The "knee" in the vented version will sound like it looks, obvious. Generally speaking a box volume >> Vas means you could use bigger and better driver in that box volume with Vas near Vbox. Also shown (in red) is the Dayton RS180 in a 20L box where Vas = Vbox. The F6 looks ideal for sealed box HT use, also possibly in a TL. see here : http://www.iplacoustics.co.uk/ipl_s3...issionline.htm |
#9 | |
thanks for the excellent links. I had tried downloading winISD the other day but the server was down for some reason. Also, I do not directly correlate intelligence with posts count. There are many with more than me that are dumb as rocks. anyhow thanks. definately helps a lot. |
#10 |
If you want the most bang for the buck combo for 2-way in MT or MTM configuration, consider Dayton RS180 and Seas TBFCG (or TDFC). Most people in DIY currently agree that these are hard to beat. If you like substantial low end, 2.5 way TMM in a tower will be a great idea.
Roman B designed a 2.5 way crossover for the RS180, but this design uses RS28A tweeter. So if you want to use a different tweeter, you'll need to modify the tweeter net. Here's a link: http://www.rjbaudio.com/RS180MTM/rs180-rs28-mtm.html |
| Speaker guy looking for a CD player kit. Advise? | R-Carpenter | Digital Source | 2 | 16th April 2008 12:59 AM |
| Please advise on a project | amo | Multi-Way | 3 | 16th July 2007 08:54 AM |
| I need advise for three channel Parallel LM4780 project. | Padel | Chip Amps | 8 | 21st November 2005 11:27 PM |
| The HDS-XLS speaker KIT from d-s-t.com.au and WES componets - Need some advise | JoeyJoJo | Full Range | 1 | 25th May 2005 05:13 PM |
| Page generated in 0.11506 seconds (82.71% PHP - 17.29% MySQL) with 11 queries |
