Well currently I plan on making some new two-way speakers for my stereo system. After listening to a friend system at school I decided to use planar-magnetic tweeters. Now I like my speakers to not only sound good but for the speaker drivers to match.
The specific tweeter I plan on using (though it isn't set in stone) is the Dayton PT2B-8 (it was the one that my friend uses so I know I like the way it sounds). Does anyone know of an affordable planar midrange/woofer that would work well with it? I am willing to change the tweeter I am using so long as it is still low cost. |
#2 |
You might want to take a look at the Bohlender Graebener (aka BG Corp) transducers at Parts Express:
http://www.partsexpress.com/webpage....ctGroup_ID=577 BG Corp web site: http://www.bgcorp.com/ Some testing of the big RD-75: http://www.audioxstream.com/testing.html -john |
#3 | |
#4 |
Zaph has published some very useful tests of planar and ribbon tweeters here: http://www.zaphaudio.com/nondomes/. Of the ones he tested he liked the Bohlender Graebener Neo3 PDR most. The rest of nondome tweeters had relatively high distortion at lower frequencies which would force you to use a higher crossover point. This in turn suggests a smaller woofer that has a relatvely high crossover point and careful crossover design. Zaph also documents this issue here: http://www.zaphaudio.com/Givler1.html
#5 |
The Soundon audio maybe is a good choose for you.
http://www.soundon-audio.com/accessories.htm |
#6 |
Hi denbo123,
do you work there? do you have a distributor (in small quantities) for the West? do all the speakers have technical specifications, with them being tested in the factory? Just asking. |
| Full range planar speaker using neo magnets | JAMESBOS | Planars & Exotics | 269 | 16th May 2013 01:16 PM |
| Anybody seen this type of planar speaker? | WrineX | Planars & Exotics | 18 | 20th August 2012 02:36 AM |
| My DIY planar speaker! | Matt MacBeth | Planars & Exotics | 5 | 1st July 2010 09:29 AM |
| Need help picking a mid.. | PoorSound | Multi-Way | 44 | 4th September 2007 07:57 PM |
| need some help picking some 3-ways | adolphe | Multi-Way | 17 | 6th September 2005 04:53 AM |
| Page generated in 0.65627 seconds (100.00% PHP - 0% MySQL) with 9 queries |
