Old 26th May 2007, 03:28 PM   #1
andy2 is offline andy2  United States
Default What lacquer type that does not smell
I've used Deft Lacquer but after about a year, it still smells (though much less). I am planning to resand and reapply some other brand of lacquer that hopefully does not smell as bad.
If I could do it all over again, I would have used Shellac which has no smell at all.
I would appreciate if someone could recommend a brand.
Old 26th May 2007, 06:57 PM   #2
I prefer to use water-based polyurethane varnish. No solvent smell, low toxicity, easy to apply with a cheap foam brush, water clean up, fast drying. They don't build up fast, though, so at least three coats are needed.
The difference between theory and practice is that in theory there is no difference between theory and practice, but in practice there is.
Old 26th May 2007, 07:28 PM   #3
bear's Avatar
Something wrong, if any paint still smells after drying.
Is it dry, hard??
Contact Deft, and see what they say.
Lacquer should not smell after it dries.
(Unless maybe if you burn it... )
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 26th May 2007, 07:36 PM   #4
jackinnj's Avatar
I've used Deft for years -- did you get some water in it perhaps, or use a turps?
For a superb finish which definitely won't outgas VOC's after it's cured consider simple shellac flakes dissoved in methyl alcohol.
Old 26th May 2007, 08:01 PM   #5
impsick is offline impsick  United States
impsick's Avatar
All laquer smells. At least when applying. I've used deft many times but never had it smelling after it was dry. Water based finishes wont wont smell as strong.
I have always had good results with deft in a spray can. for small projects.
I've finished many hardwood floors and never had that problem with it smelling after it dried. thats kinda odd. maybe the can you had was bad or our you applied it too thick, i dont know. thats really wierd.
deft is a good brand if you ask me. maybe just do a light sand and recoat it with a new can of finish.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 26th May 2007, 11:04 PM   #6
Originally posted by impsick
. maybe just do a light sand and recoat it with a new can of finish. [/B]
I am thinking of doing this. Resand but this time will spray one thin layer at a time. It doesn't smell that bad, but if I put my nose close enough it smells. Or if I leave the in an unventillated area during a hot day, the smell could be felt in the air.
I also use Deft lacquer on another pair of speaker but that doesn't smell as bad though.
Hopefully resand and spray will solve the problem.
Old 27th May 2007, 04:28 AM   #7
impsick's Avatar
ya it seems like maybe the can you had was bad or maybe when you applied the coat it made a chemical reaction with something that was left on the wood. I dont know, but yeah keep the next coat light and you should be fine.
How do I get rid of that rubber smell? grimberg Everything Else 0 31st July 2008 09:27 PM
Do all lacquer smell the same? andy2 Multi-Way 25 3rd June 2006 12:45 PM
When will lacquer smell go away? andy2 Multi-Way 5 17th May 2006 01:23 AM
Page generated in 0.08635 seconds (74.00% PHP - 26.00% MySQL) with 10 queries
