Old 25th May 2007, 10:20 PM   #1
Default DM22 Refurb questions
So I picked up a clean pair of B&W DM22's today.
I'd like to do some maintenance on them.
The crossover has 27 year old electrolytic capacitors that I believe should be replaced.
Unfortunately, i can't seem to find the exact MFD rating. It has 9 and 4, but the closest I can find are 10 and 3.3
Is it okay to use those in a crossover?
Any other bits I Should swap out while I'm in there? I figure I'd replace the wiring as well, but I'm unsure if I need to change the inductors/resistors/etc.
Old 26th May 2007, 02:50 AM   #2
Default Re: DM22 Refurb questions
Old electrolytics should definitely be replaced, preferably with film type caps. Those are the most common in quality speakers and it's very easy to get your hands on the values you need. Using approximative values is not recommended as it will change the Xover frequency. Evn though it's not critical you could also swap ferrite-core inductors for air-cores but in that case you'd have to take the inductor's own resistive value into account. This could affect the sound if there are many coils on the Xover.
latest on kef 107 refurb dayking79 Multi-Way 16 4th November 2008 11:35 PM
Is my amp getting tired and in need of refurb? nailzgun Solid State 8 18th August 2008 11:34 PM
Maggie refurb project radtech Tubes / Valves 17 24th March 2007 12:28 AM
Old system refurb elousv Multi-Way 1 21st September 2005 11:07 AM
Some newbie questions on refurb Jim B Solid State 3 7th April 2004 08:17 PM
Page generated in 0.15098 seconds (38.52% PHP - 61.48% MySQL) with 10 queries
