I purchased a set of Sears (Audio by Fisher) Full Range speakers (estimated date of manufacture around 1980). They have been modified prior to my purchase to use an alternate inputs (one for high/mid range, another for woofer) individually, rather than the intented receptacle on back of cabinet.
Inside the cabinet is a small card with caps and filter coils, which has been disconnected in favor of using the alternate inputs to drive the speakers. My question is given the information below, does anyone have the correct configuration or a diagram for the card, that I can use the return the cabinets to their intented configuration? Sears Audio by Fisher Model Number 143-94194800 Woofer = 15" Midrange (X2) = 5" Tweeter = 3" Horn NL-8185-104 |
#2 |
What I'd do is to take the Xover to an electronics design/repair shop -ideally one specializing in audio design- and have them measure the values of the components for a small fee. As for how they are connected to each other you can usually determine that yourself visually by simply following the printed circuit on the board.
#3 |
If you post enough details we can work it out for you. |
#4 |
If you post a photo of the cross-over (small card with caps and filter coils) I'm sure you will have your answer in no time.
In lou of the photo you could sketch out a schematic (diagram) and post that. |
| Original Bose 901 Internal Wiring Diagram | sdep777 | Full Range | 24 | 28th February 2010 05:14 PM |
| need diagram fisher receiver 600T | november | Solid State | 1 | 2nd July 2009 03:59 AM |
| internal block diagram for CXD1135Q | heilman | Solid State | 2 | 6th March 2007 07:07 AM |
| Suggestions for full-range internal speaker wiring? | coolkhoa | Multi-Way | 5 | 26th January 2004 01:13 AM |
| Page generated in 0.08490 seconds (83.76% PHP - 16.24% MySQL) with 10 queries |
