Old 24th May 2007, 04:50 AM   #1
Default Attatching grill cloth
I had a friend help me with the box building for a pair of speakers I recently built and he had a great idea for doing the grills. I don't know if this has been discussed before, but this is what he did.
He built a slim wood frame for the grills and before fastening the four sides together cut a narrow grove down the back of each piece. I stretched thin fabric over the frame and used screen door rubber tubing to attach the fabric to the frame. It was super easy and would be easy to replace the fabric if needed.
Steve
Old 24th May 2007, 06:04 AM   #2
Very practical and a nice idea.
Gajanan Phadte
Old 24th May 2007, 06:26 AM   #3
bastek is offline bastek  United States
I don't get it. My parts express grills have a groove in the back. They came without instructions. I was about to prepare some contact cement, when i read this. How exactly you do that?
Thanks.
Old 24th May 2007, 09:14 AM   #4
Geek's Avatar
Sorta like a window screen, brilliant!
Old 24th May 2007, 10:51 AM   #5
Thanks.
Here's a link to "Home Tips DIY." It shows how to replace the fabric in a window screen. The same principle should work for speaker grilles that have the groove on the back of the frame.
http://hometips.com/articles/repair_window_screen.html
Old 24th May 2007, 01:30 PM   #6
sdclc126's Avatar
You can also use the screen door material itself as the grille "cloth" - use the black stuff and mount it at a 45 degree angle so it forms a diamond pattern - you end up with a grille you can see the drivers through and a hi-tech look. Similar to a perforated metal screen but obviously easier to make.
Soft Dome
Old 25th May 2007, 02:22 AM   #7
You can buy a small tool that has a wheel with a groove that you run over the rubber tubing to press it into the groove. The tubing is round, hollow and has small ridges running the length of it.
Steve
Old 25th May 2007, 03:04 AM   #8
I' ll try that tomorrow. Thanks
Old 25th May 2007, 10:53 AM   #9
To help with getting the tubing in the groove,stretch the tubing with one hand and use the roller in the other hand.At the end of each side,release the tension and it will strech back to fill the slit.
And yes,spend the 3-4 dollors on the roller! It will avoid you putting a hole in the grill cloth with a screwdriver!!!
When you get the tubing done,use a razor blade between the tubing and the outside edge of the groove to cut off the extra grill cloth.
(I used to redo screens for a local lumberyard when in highschool for extra $$)
Fabric for Speaker Grill Cloth <-- suggestions? jaencer Multi-Way 26 5th August 2011 05:37 PM
Vandersteen 2C replace fabric grill cloth skyhigh_ct Multi-Way 1 28th October 2008 12:19 PM
Scrap grill cloth needed warrior05 Swap Meet 0 18th October 2006 03:41 AM
Acoustical foam grill cloth? woody Multi-Way 0 13th January 2003 12:10 PM
grill cloth in port zach Multi-Way 5 27th October 2001 08:56 PM
Page generated in 0.09255 seconds (76.60% PHP - 23.40% MySQL) with 10 queries
