Old 24th May 2007, 12:03 AM   #1
akunec is offline akunec  Canada
Default Determining Acoustic Center
Would it be possible to determine the acoustic center relative to another driver by applying a burst of noise to the driver, and measuring how long it takes to reach the mike? Then measure how long it takes for the other driver, and subtract the difference?
Alex
Old 24th May 2007, 02:05 AM   #2
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
In theory I think so, but I really shouldn't be answering this....not sure how you would "time" the difference.
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 24th May 2007, 04:02 AM   #3
I would have 1 input as a signal from the amplifier, and another input as the microphone.
Old 24th May 2007, 08:06 AM   #4
cs is offline cs  United Kingdom
Sounds like a good idea !
I think to get the most accurate result, you would need a signal which only occupies the spectral region where the two drivers overlap. Maybe two closely spaced tones would work, as you could use the envelope of the tones to measure the delay.
Old 24th May 2007, 08:31 AM   #5
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default Re: Determining Acoustic Center
Alex
You have it spot in. That is exactly the way to determine relative acoustic offset.
see here
Evaluating relative acoustic offset
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Acoustic center of horns mrkramer Multi-Way 5 29th January 2009 08:32 AM
Dynaudio D76 Acoustic Center? DaveThreshold Multi-Way 2 20th May 2006 11:35 PM
Acoustic Center? angsuman Multi-Way 5 18th April 2006 10:25 AM
COmputer program for determining acoustic centres 5th element Multi-Way 9 14th March 2004 01:30 PM
COmputer program for determining acoustic centres 5th element Music 3 13th March 2004 09:21 PM
Page generated in 0.07864 seconds (72.65% PHP - 27.35% MySQL) with 10 queries
