Old 23rd May 2007, 07:04 PM   #1
akunec is offline akunec  Canada
Default Ground Plane Measurements: Determining delay / offset
I just made some ground plane measurements of my speakers mounted in their cabinets with a 42ms time window. In order to calculate the acoustic center offset between the drivers I did the following:
Mounted microphone at 2m on tweeters axis.
Measured tweeters response and calculated its phase using HBT.
Measured mid's response (and shifted volume until its about the same as the tweeter). Determined phase using HBT.
Measured tweeter and mids response together.
My understanding is that when I tested them together, it would tell me of how much they are in phase with each other. So I imported the mid data and tweeter data into LSPcad and put a delay on the tweeter. I adjusted the delay (using optimizer) until I reached the transfer function of the combined mid and tweeter response.
I achieved a delay of only 5.13 microseconds, which really doesn't seem right. Can anybody tell me why this didnt work?
star ground vs. ground plane Sebastiaan Chip Amps 15 10th May 2009 05:05 PM
Using Ground Plane on Both sides of Board? ppl Solid State 11 13th October 2006 04:14 PM
ground plane interference with output mazurek Solid State 0 17th August 2006 10:14 PM
Eagle PCB Ground Plane Question Algar_emi Everything Else 6 26th January 2006 02:36 PM
I discovered CDP ground plane. What should I do with it? DIAR Digital Source 18 4th December 2004 12:29 PM
Page generated in 0.10385 seconds (59.05% PHP - 40.95% MySQL) with 10 queries
