Could someone help me with the following questions? 1. Currently I'm experimenting with Leach's math for low frequency horns. It seems that when the horn's bandwidth gets wider, the system efficiency decreases and the throat gets smaller. But according to 'classic' horn theory the efficiency increases when the throat is made smaller. How come these theories predict different results? 2. Does the compression ratio play an important role in horn design? What are the consequences of a CR that is too high? It seems that Leach's math results in quite small throat areas, but the simulated response is flat in most simulations. Also, in the "System design from specifications"-section Leach uses a CR of 4:1, which is considered as being high. Why did he do that? 3. For the driver I'm using/simulating, it seems that I can get a flat response only when I use a high compression ratio. Increasing throat area results in dips and peaks. Should I conclude that this driver is not suitable for horn loading? Are there any other horn design methods/approaches, other than Leach's? Or is Leach the only correct approach for calculating system parameters for a given bandwidth? 4. It seems that the throat on midrange horns is made equal to Sd (CR 1:1) in many designs. Is this just a 'rule of thumb', or can it be calculated? 5. How important is the voice coil inductance corner frequency? Does it play a major role on the HF response of a (midrange) horn? 6. Is a throat chamber (for HF rolloff) required for a midrange horn? 7. It seems that some people substitute Qes for Qts in design formulas. Maybe because Qts ~ Qes is assumed. But in case of a dual voice coil driver with one coild shorted, the difference between Qts and Qts is significant (Qts ~ 0.5Qes); So it becomes important to know which one I should use. Could someone explain this? I greatly appreciate every reaction. Erwin. |
#2 |
Another question came up to my mind.
In his Loudspeaker Design Cookbook, Dickason mentions that a driver's dustcap made of textile causes air leakage. Could this become a problem when the driver is used for horn loading, because of high pressure at the throat section? |
#3 |
frugal-phile(tm)
Cloth surrounds can leak to. Yes this can be a problem (or a feature)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 | |||||||||||
Since I have CRS, and have not looked at the horn design equations in a long time, I may get some things wrong or have forgotten them...
IF the bandwidth is increased, the efficiency decreases, so this may account for what you are seeing. Keep the bandwidth the same, and the efficiency should increase.Quote:
It means that the forces acting on the cone are high, and that there is potential for added distortion. Not to mention destroying the cone by rips or tears... depending on the levels the thing is played at. Keep in mind most horns were used for PA/SR where the levels are near or at max for the drivers. Quote:
There is a figure of merit for cone applications. Also, there is an implied relationship between the driver and the horn - namely that the horn supplies the necessary boost in LF response to make the overall response look flat. Above some freq the horn really doesn't do much of anything. Below some freq, the horn adds gain. Flatness in a horn usually depends on adequate mouth size to support the LF without "comb filter" looking dips, and the proper flar e rate for the freq of interest - but the mouth size is a big deal. Quote:
Usually the methods are based on Webster's equations. Many variations and references, including online. Quote:
Think about what a standard compression driver sounds like without a horn on it? All highs... rolls off going down in freq... the horn pulls that back up. Ok? Quote:
Reasonably common technique in bass horns, though... Quote:
How does the excursion of a standard driver look wrt to frequency? IF you kept the excursion "constant" wrt frequency, what would the freq response look like? Now, if you took that second driver and hooked it up to a horn, what would the freq response look like with and without the horn? Qe dominates in the horn loaded situation... I think that is why Qt is disregarded. Btw, I do not think you want to short one coil. That will create extra heat, as the coil will try to act like a brake. Reduce output too... Maybe there is a good reason to short a VC, but I'm not sure what that would be... Quote:
_-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#5 | |||||
Hi bear,
Because of this observation/relation it seemed reasonable to me that efficiency can changed only when bandwidth does too. That's also why I wasn't sure about the 1:1 throat on a midrange horn; Such a throat would result in a very narrow bandwidth. However, Bruce Edgar mentions in his Midrange Horn article that the upper end response increased by making the throat equal to Sd... Quote:
Thanks for your help. Quote:
Although I certainly don't question the accuracy of his simulations, HornResp shows different results for these high Q drivers. Which tool is more 'reliable', and why? regards Erwin |
#6 |
anyone?
#8 |
...truth seeker...
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#9 |
...truth seeker...
How does Leach compare with LeCleac'h?
http://ndaviden.club.fr/pavillon/lecleah.htm click on: "Telechargement" http://ndaviden.club.fr/outils/axial.zip
#10 |
Greets!
Hmm, increasing the CR implies an increasing acoustic power/watt, ergo decreasing the CR implies an increasing acoustic efficiency and wider BW. ML's math is for compression loaded horns while JMLC's is more along the lines of low diffraction termination waveguides. I don't use Hornresp, but MJK's sims of ML's math have shown good enough correlation with my 'adventures' in using non-optimal drivers with Qes as high as ~3.3! to satisfy me, though as always YMMV. Bottom line, in any line of work (audio app), you want to use the right tool (driver) for the job (speaker alignment), so using non-optimal drivers requires trade-offs that you'll have to choose which ones are acceptable. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
| how to go from horn response to a folded bass horn design? | paulspencer | Subwoofers | 8 | 4th November 2005 10:44 PM |
| horn questions | e-side | Multi-Way | 39 | 22nd August 2005 08:39 PM |
| Horn questions | slackerbob | Subwoofers | 11 | 1st August 2005 10:31 PM |
| A some horn questions | mashaffer | Multi-Way | 3 | 19th May 2005 02:58 PM |
| Fostex 103 horn questions | GrahamnDodder | Full Range | 12 | 2nd March 2004 06:53 AM |
| Page generated in 0.14151 seconds (85.32% PHP - 14.68% MySQL) with 10 queries |
