Old 21st May 2007, 04:03 PM   #1
exurbia is offline exurbia  Australia
exurbia's Avatar
Default In the wrong place ?
Before i was struck down by my mystery illness (myelitis) i was a bit of a speaker builder.
The following are a couple of pics of my last project. It took me over a year and selling almost all of my "stuff" to complete.
I had to eat after all.
The boxes are made of 25mm MDF side panels with a strip laminated front,top,back and base. The veneer is Tasmanian Myrtle one of our finest cabinet timbers.
The drivers are a slightly modified Seas LR15 and a Foster dome from Dave @planet ten X/O is 2k third order electrical on the Foster and Second on the Seas. All internal wiring is twisted Copper and Silver, the umbilical from the X/O to the box is Silver Teflon Mil-spec wire. The X/O's use Foil air cores and a variety of silver foil in oil caps.
Now i am officially in remission and taking one of the new wonder drugs. I intend to do a lot more now. When i was told i may only have weeks to live i realised how much time i had wasted.
Hopefully my next project will be a bit "special"
Many thanks to all who wished me well and bought stuff from me.
Old 21st May 2007, 04:11 PM   #2
exurbia's Avatar
Bah, I can't attach the pictures.
Oh well, i sent some to Dave @ planet ten maybe he can load them up for me
Old 21st May 2007, 04:45 PM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
I whish you all the best in these difficult times, exurbia.
Don't look back at the wasted time but cherish the good moments you had. I’m sure there will be many more to come.
/Hugo
Old 24th May 2007, 11:44 AM   #4
exurbia's Avatar
Old 24th May 2007, 11:46 AM   #5
exurbia's Avatar
nother one
Old 24th May 2007, 11:48 AM   #6
exurbia's Avatar
and again
Old 24th May 2007, 12:27 PM   #7
Hartono is offline Hartono  Indonesia
nice speaker
Old 24th May 2007, 12:41 PM   #8
Did it Himself
richie00boy's Avatar
Interesting, it looks like a load of end-on MDF panels. So the middle section is actually a veneer? Is the whole lot varnished or lacquered?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 24th May 2007, 02:06 PM   #9
exurbia's Avatar
The side panels are 25mm thick mdf the "insides" are made of 12mm mdf laminated with polyurethane glue as the binder. Each 12mm panel had the guts cut out to an L shape. The L's were put end to end and pinned and glued. using wooden pins similar to a chopstick. After the cabinet was completed the veneer was added. The whole lot then got a good soaking with Linseed oil and was finally burnished to the eggshell gloss in the picture. There is no wax or non organic finish used, as the "Beer Midget" isn't so keen on the odours generated.
Old 24th May 2007, 02:09 PM   #10
Did it Himself
Ah now I get it, the veneer is only on the side panels.
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Might speaker filters be in the wrong place? beamnet Tubes / Valves 14 9th December 2007 07:52 PM
2x 2Sk170 in place of 2SK389 and 2x 2SJ74 in place of 2SJ109? jarthel Parts 12 26th July 2007 09:08 AM
I have a kind of UcD survey question, maybe it's in the wrong place... ptwining Class D 5 30th March 2006 05:33 PM
Best place to place bleeder resistor in a power supply? G Tubes / Valves 13 4th August 2004 09:26 AM
Page generated in 0.09640 seconds (79.50% PHP - 20.50% MySQL) with 11 queries
