Old 21st May 2007, 02:19 PM   #1
Question 2nd Order Crossover & Phase…
Am I right in thinking that if you have a 2nd order crossover the tweeter needs to be ‘out of phase’ but if I can recess it back from the mid/bass driver then it wouldn’t need to be reversed wired? If the crossover point is 3000hz the is there a calculation as to the depth difference?
See also this thread:
Ribbon Tweeter advice please
Old 21st May 2007, 02:23 PM   #2
Did it Himself
richie00boy's Avatar
No the reverse phase connection assumes perfect physical time alignment. So in fact if you have a step you may be better off with in phase connection. You are best trying both and see. I think Svante might have some software to help.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 21st May 2007, 02:44 PM   #3
sreten is online now sreten  United Kingdom
See this thread :
BAMTM Tweeter polarity
Related to this crossover :
http://www.zaphaudio.com/BAMTM.html
/sreten.
Old 13th June 2007, 09:34 AM   #4
Update…
For this single project I shall not be spending on specialist computer software, microphone, new soundcard, etc. instead I shall be groping around in the dark, well, semi dark at least, using my ears and basic maths. I have a calculated crossover which I have tried on one (mono) speaker and nothing disastrous happened! I’ll now assemble its twin and see what stereo sounds like.
Crossing over @ around 3400hz Visaton tweeter @ 8ohm Volt mid/bass @ estimated 11ohm I have a roughly (!) Bessel crossover with tweeter 3.3uf cap .68mh ind. Bass/mid 2.2uf cap .82mh ind. With a suitable L pad.
Thoughts? And will the Visaton need ‘running in’ before worthwhile results are heard?
Addendum:
In mono it seemed better with tweeter in phase.
I have a few test Cds with test tones etc is there anything specific to listen to that will uncover flaws in the crossover?
Old 13th June 2007, 11:01 AM   #5
jnb is offline jnb  Australia
If you are using a second order electrical crossover, it seems unlikely that your acoustic response is second order.
Old 13th June 2007, 05:01 PM   #6
Jay_WJ is offline Jay_WJ  United States
Try simulation. You'll get much better results than simply by relying on text-book formulas and listening.
1. http://www.rjbaudio.com/Audiofiles/FRDtools.html
2. http://www.rjbaudio.com/Audiofiles/SWtutorial.html
3. http://www.rjbaudio.com/Audiofiles/d...alculator.html
Good luck,
Jay
Old 13th June 2007, 10:42 PM   #7
DynoPort,
Totally agree with Jay. Take the time to learn and use the above simulation tools. In addition - use a crossover modeler once you have simulated the response of your drivers and created minimum phase using the above tools - plugging in your intended crossover above.
The above won't cost you any money - just time. In fact it is very likely to produce a better sounding speaker with less crossover iterations (= less $ spent on crossover parts to get it right) than listening and tweaking by ear.
David.
Old 14th June 2007, 08:19 PM   #8
I cannot open 'speakerworkshop' I get a 'cannot run 16-bit program, it or one of its components is missing' message on clicking setup after I unzip it?
Old 15th June 2007, 10:15 AM   #9
However, it does work on another computer!
Crossover order and phase shift NV&H Multi-Way 1 28th December 2008 08:31 AM
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
Phase coherent, low cost, 4th order XO rick57 Solid State 20 15th April 2003 03:55 PM
Which 4th order XOs are phase coherent? Are SWs of value? rick57 Multi-Way 0 14th April 2003 03:40 AM
Crossover order and phase question Westrock2000 Multi-Way 36 31st March 2003 07:00 PM
Page generated in 0.12894 seconds (74.29% PHP - 25.71% MySQL) with 10 queries
