We live in a horizontal world, why use vertical topologies??? |
#2 |
#3 |
Looks like fun. How does it sound?
Kensai |
#4 |
Its sounds very good considering the money I spent on these.
400 swedish kroner, almost same as 40 dollars. They are cheap 5 inch caraudio speakers, but they can realy play bass!!! The have a lot of output down to 50 hz, a bit to much at the moment, but with some dampening of the cavity behind the coaxial, and some wool in the vent i think they will sound very nice. The bass is very strong and dynamic. It sound a bit like a horn. They are built to serve as computerspeakers, but my girlfriend wants them in our kitchen. A good sign i suppose!
#5 |
Do you have dimensions for the cabinet? I have a pair of Advent 5.25" full range car speakers that would probably work in your BVR. Thanks, NOXO.
#6 |
Sounds like maybe the enclosure volume is a bit too low, causing a taller peak at the tuning frequency.
Anyway, I really wish car audio manufacturers would publish specs on their drivers . . . would make it alot easier to build decent enclosures for drivers that can be had locally. Kensai |
#7 |
The outer dimentions are (Height x Width x Depth) 465 x 232 x 332 mm. Thickness is 16 mm in all walls. Inner width is 200 mm.
The port starts 200 x 10 mm and ends 200 x 100 mm. Its 500 mm long. The enclosure volyme is 12 liters. Enlargening it in Hornresp gives a lot more peas and stuff. You have all data in my picture of Hornresp. Johannes.
#8 |
Circlomanen, thanks for the dimensions, this will be one of my next projects.
#9 |
frugal-phile(tm)
I love the stuffing in the port
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
| Bipolar MLTL with 5,25 inch car coax | Circlomanen | Multi-Way | 10 | 19th September 2008 04:54 PM |
| 8 inch RCF coax | holger honda | Multi-Way | 9 | 18th November 2004 06:05 PM |
| Flexible, small diameter coax...??? | Tieftoener | Digital Source | 2 | 18th November 2003 04:13 PM |
| Passive Radiator system with 2x10 inch and 1x15 inch | Lach O'Sullivan | Multi-Way | 3 | 13th September 2003 03:29 PM |
| Page generated in 0.54613 seconds (16.79% PHP - 83.21% MySQL) with 10 queries |
