Apogee Centaur Woofer upgrade
Old 3rd March 2008, 06:16 AM   #21
DAMIC is offline DAMIC  Serbia
Centaur Minor's sensitivity is about 83-84dB. I have old but still excellent Luxman L-530 rated at 120w (20w in A class) and this is just enough for C/M.
Your amp could be good but only upto medium levels, so don't push it too hard.
Old 4th March 2008, 01:31 PM   #22
R.I.P.
Originally posted by hifive
What is the sensitivity of centaur mini?. I'm using Naim 202/200 with 70wpc, is it a good match?
Simply depends on what loudness you exspect. 150W a channel is
only 3dB more and barely makes much difference in max volume.
The Apogees are inefficient, and will not go loud with any amplifier.
The Naims should have no problems driving the low mid / treble
impedance and I'd say likely a better match than most.
/sreten.
Old 5th March 2008, 09:32 AM   #23
otto88 is offline otto88  Australia
otto88's Avatar
I had Centaur Minors, fantastic upper mids & treble. But sold them due to lack of bass quantity and to some extent quality. .
In retrospect, and for you Rozz, why not handle up to 100 Hz with good sealed subs, eg Linkwitz sealed Thor subs - active . . simple build, SPL limited, but very low distortion & go down to 30 Hz
http://www.linkwitzlab.com/thor-intro.htm
Or better still, a dipole woofer, this one odd looking but great natural bass http://www.linkwitzlab.com/woofer.htm
btw, what's the sensitivity of the Centaur Major?
Cheers
Old 5th March 2008, 10:23 AM   #24
Cheers
Major's sensitivity is 83dB @ 3m according to info from link
http://www.apogeespeakers.com/
look under hybrid's.
Old 5th March 2008, 12:16 PM   #25
otto88's Avatar
If Vifas are used, you avoid spending any time or money redesigning the current professionally designed XO (though parts quality may be improved - at http://www.apogeespeakers.com/ see Projects).
Also if you divert time & money to getting good subs (compared to the 90s, high Xmax low distortion subs drivers are affordable) taking the bulk of the bass load from the Vifas (most of their work), should significantly improve their performance 100 - 800 Hz - the critical midbass - lower midrange, where most of the musical energy is.
Cheers
Old 30th March 2014, 01:21 PM   #26
Akritaspowersound is offline Akritaspowersound  Cyprus
Talking Centaurus Minor - Original Woofer T/S Parameters
Hello All,
Does anyone has the T/S parameters of the original woofer of the Centaurus Minor? I need them so i can choose a Focal Driver with parameters as close as that.
I want to start fixing my apogee speakers.
I currently have 3 x Pairs of Duetta Signature II, 1 x Centaurus Major, 2 x Centaurus Minor, and 3 x Diva's.
I will keep posting here my adventures if you are interested
Old 16th November 2015, 06:43 PM   #27
sahranna is offline sahranna  Germany
Default T/S-Parameters Vifa 6.5
Hi, I know I'm a little late, but maybe it helps.
Apogee Centaur Woofer upgradeHide this!Advertise here!
Apogee Scintilla amp Thomas B Pass Labs 32 24th September 2015 08:21 AM
22W/4851T Revelator 8" woofer an upgrade for 21w-8554? Daveis Multi-Way 0 9th October 2007 02:14 AM
Woofer upgrade Help AR_sound Multi-Way 7 28th September 2006 05:26 PM
12" woofer upgrade - sealed or ported? Sparhawk Multi-Way 2 6th March 2006 07:32 PM
ESS AMT-1D Woofer upgrade 1970 RS Z28 Multi-Way 2 4th October 2004 01:02 AM
