Old 17th May 2007, 07:30 PM   #11
Timn8ter's Avatar
Man, when I saw "bush speakers" for some reason I thought of these.
Old 18th May 2007, 04:28 AM   #12
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default Re: Help needed in making cinema speakers!!! noob!
Originally posted by lions_gym
hi,
just started out making subwoofer enclosures etc which is pretty noob anyone can do it.
im currently starting a project to make 2 wall mounted cinema speakers.
these speakers are my inspiration and what i want mine to look like at the end:
why not double up on this design from John K.
http://www.zaphaudio.com/audio-speaker20a.html
...still looking for the holy grail.
Old 19th May 2007, 12:58 AM   #13
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
[B]
would it be possible to wire up those 4 drivers (mids and tweeters) to make it a 4 ohms speaker. Can someone show me the wiring, would i need to get a crossover?? is it necessary.
You will need a crossover on any design like that. A well designed crossover will take into account the drivers frequency response, enclosure dimensions, impedence and physical distance between them among other things.
Cosmetically those drivers in post #1 look interesting but without any specs theres a very good chance they would not be right for your application. Unless you intend to measure everything yourself including frequency response it will likely be a waste of money.
To make a 4 ohm speaker like that you will have to use 2 8 ohm woofers and run them in parallel. Your tweeters wouldn't matter as much as you will be able to change that through the use of an L-pad.
Old 19th May 2007, 04:22 AM   #14
navin's Avatar
Originally posted by sreten
Each cabinet will be 4 ohm.
Re-use the grills, grill mountings, input cups etc ...
If an amplifier says it needs 8ohm speakers, it does.
asking an amp rated at 8 ohms (but not less) might be taxed driving a 4 ohm speaker at higher volumes. At lower volumes as long as the amp can deliver the amps it should be ok. is the amp is rated for a 4 ohm load then all is fine.
Old 19th May 2007, 09:43 AM   #15
ok,
is there anyway to make a 4 ohm speaker into 8 ohms for my amp.
if not, would i be able to drive a 4ohm speaker with a philips mx5700d dvd home cinema amplifier. also what is 100w at 1khz???
does that mean it can only put out 100w rms to 1 khz frequency the power drops??? its a class d amplifier.
Old 19th May 2007, 09:43 AM   #16
also you recommended those bush bookshelf speakers from richer sounds.
How does the acoustic solutions av20 from argos at 20 pounds compare with the bush ones? they have VERY similar specs.
Old 20th May 2007, 12:52 PM   #17
bump
Old 21st May 2007, 07:34 AM   #18
I understand where your coming from. I bugged people on forums like these plenty trying to get someone to make my creative yet terrible idea to somehow work. I made my own frankenspeaker and then i moved a month ago and my speakers i just buit sounded 10 times better for eaquil cost.
You can change between 4 ohm and 8 by wiring 2 identical speakers in parallel or series depending what direction you want to go. this is crude and pays no attention to power handling or sq but it will do what you want i believe, it will make them significantly louder or quieter as a side effect too. If I where you though, I would spend more time on looking at drivers zaphs hi-vi solution on his webpg is very cheap and i dont think you will get a better sounding speaker for the price.
if you want the wedge shape, like one navin said, you could double up zaphs hivi satellites and put them on a steep angle so that one side acts as side channels, and one side acts as rear bouncing off a wall behind you.
most importantly, do allot of reading on here, im no good at this stuff so I busted my butt reading every snippit of wisdom that flies around here.
While your at it, take a look see at my concept cabinet designs:
http://www.htguide.com/forum/showthread.php4?t=25916
Old 23rd May 2007, 07:57 AM   #19
Thanks for the reply mate, much appreciated.
Im going to scrap making the speaker and just buy a nice pair of bookshelves, then if i feel crazy enough ill cut them diagonally and stick them together to make that dipole ive been wanting. lol
but for now thanks, i think my amp will get along fine with the new speakers i buy.
cheers mate
lions_gym
Active cinema speakers Thims Multi-Way 1 9th November 2008 08:31 AM
home cinema speakers skogs Multi-Way 6 7th September 2007 05:15 PM
New amplifacation needed noob! jasonsrt4 Chip Amps 9 7th June 2006 10:09 PM
Home cinema front speakers/subwoofers mcai7et2 Multi-Way 0 31st January 2003 10:53 AM
TV/home cinema speakers Hay Introductions 1 6th January 2002 04:50 PM
Page generated in 0.11020 seconds (78.86% PHP - 21.14% MySQL) with 10 queries
