is two full range drivers in one baffle a problem? - diyAudio
Old 22nd January 2003, 12:36 AM   #1
Default is two full range drivers in one baffle a problem?
If you mount two small full-range drivers like the Fostex FE103 virtically in a narrow baffle, will it sound worse than just one? Meaning if one sounds good, will two sound the same, just louder? Or can adding the second one screw up the imaging? If so, how can you tell what kind of spacing (like D'Appalito) there should be between the drivers so as to not screw up the imaging?
-Brad-
Old 22nd January 2003, 12:54 AM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: is two full range drivers in one baffle a problem?
Hey baffle-man
The answer is, in theory, yes. At some frequency related to the distance between the 2 drivers the HF will start to add & cancel. An MTM XOs the 2 mid basses low enuff low enuff to avoid this. With 2 FE103s as close as possible this is in the 4-6k region.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd January 2003, 01:06 AM   #3
BAM is offline BAM
Send a message via AIM to BAM
Default 1.5-way
One could slap a low-pass on the bottom wide-range driver, and thus make the speaker a 1.5-way.
Old 22nd January 2003, 01:09 AM   #4
Any way to remove or reduce this problem? Stagger the drivers with their centers not virtically alligned? Place them side-by-side?
Firing at different slightly different angles?
-Brad-
Old 22nd January 2003, 01:20 AM   #5
frugal-phile(tm)
planet10's Avatar
You can mount them co-axially (quite difficult in 3-space ) or at an angle of at least 90 degrees (and if you are going that far you might as well do it 180 degrees and take advantage of push-push.
dave
Old 22nd January 2003, 01:45 AM   #6
Does the cancellations happen in close proximity to the drivers or farther out? Would putting something like neoprene rings on the baffle around the drivers help to reduce this bad effect?
-Brad-
Old 22nd January 2003, 03:15 AM   #7
frugal-phile(tm)
planet10's Avatar
No
dave
Old 22nd January 2003, 06:49 AM   #8
Wizard of Kelts
diyAudio Moderator Emeritus
This thread has info and references you might find instructive:
line array with full range drivers?
Old 22nd January 2003, 07:36 AM   #9
jan.didden's Avatar
Default 2 full range etc
Dave,
I always thought that if you have two drivers close together and feed them with the same signal, you can consider them as one driver with a double area. If there is cancellation, why isn't there cancellation with a single driver from signals from different parts of the cone? Or is there, what they call beaming?
Jan Didden
Old 22nd January 2003, 07:52 AM   #10
Jan,
You could consider them one driver if you could manage to have both drivers exactly the same distance to your ears. However, this is practically impossible, since at higher frequencies, minute pathlength differences will cause cancellation. Slouching just a bit from the optimum seating position will destroy the tonal integrity at these higher frequencies. This is why one tweeter is almost always used, with the other drivers LowPassed.
Dave Hull
Full Range Open Baffle and 5W triode pforeman Full Range 6 12th August 2009 02:18 AM
DIY Open Baffle Full Range Speakers from Wal-Mart . . . loudandclear Full Range 61 29th July 2009 11:01 AM
Building full range open baffle? Glowbug Full Range 27 22nd January 2007 11:15 PM
For Full Range With Subs -- Sealed Box Vs Open Baffle ? DrDeville Full Range 4 21st January 2007 06:26 PM
full range (open baffle) then_dude Full Range 15 9th March 2004 03:58 PM
Copyright 1999-2017 diyAudio
