is two full range drivers in one baffle a problem? - Page 3 - diyAudio
Old 23rd January 2003, 06:15 PM   #21
Bose(o) is offline Bose(o)  Canada
Barber pole is a way out...slight change in the direction. Saw bose 802s on the same pole and was wondering why they all we were at a slight change of angle. This would be the reason.
Just a sec here, trying to figure out the phase shift. If for example, you take two sine waves and change the phase shift for one wave by pi/2 (90 degrees), do the two waves add-up? Or, will they require a change of pi (180 degrees). The sine wave represents the sound from one Fostex.
I believe that the poor off-axis response is due to the wedge dispersion and lobing effect from using a line-array. This is good however, for use when you want to minimize reflections for PA use in a room with relatively poor acoustics. You get the same power of a larger driver without the reverberations.
Old 24th January 2003, 03:31 AM   #22
Wizard of Kelts
diyAudio Moderator Emeritus
Two sine waves of the same frequency will add together. I believe, but am not sure, that if you add two sine waves together of equal frequency but 90 deg phase difference, that you get a result that is half the amplitude of what it would be if they were in phase together.
If they are 180 degrees out of phase, they cancel out completely.
I think I mentioned once, about anti-noise. Certain airplanes have a system where the noise of the engines is picked up by mikes, sent through an amp, reversed in phase, and played in the passenger compartment. Although there are some time delays, the phase is close enough to 180 degrees that the sound of the jet engines is substantially reduced. Anti-noise = sound waves 180 degrees out of phase.
Old 24th January 2003, 04:34 AM   #23
frugal-phile(tm)
planet10's Avatar
Panasonic uses this noise-cancellation technique in their high-end video projector. You can actually be in the same room as the projector!!
It is interesting that the 1st publication of this idea was actually intended to be an April Fool's Joke
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th January 2003, 09:24 AM   #24
Pan is offline Pan  Sweden
Two drivers in paralell will give 6dB+ for the same voltage in.
Two drivers in paralell with a 90degree phase distance will give 3dB+.
And obviously at 180degree they cancell out.
At 270degree (the case with 3rd order butterworth) the situation is virtually the same as with 90degrees, so the sum is 3dB+.
/Peter
Old 24th January 2003, 09:36 AM   #25
Electrons are yellow and more is better!
peranders's Avatar
Are you sure about that? Double power = 3 dB increase in sound pressure. I think you mixed up voltage and power.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 24th January 2003, 09:53 AM   #26
Warp Engineer
On Holiday
AudioFreak's Avatar
We've covered this countless times before. Where the distance between the 2 drivers is small relative to the wavelength, you get a 3dB increase for the same total power input. So for 2 drivers in parallel at lowish frequencies, for a given voltage input, you get 6dB increase in on-axis output relative to a single driver.
Old 24th January 2003, 10:00 AM   #27
Two drivers in paralell doubles the power drawn from the amp. That gives 3dB. An extra magnet with its VC and BL factor gives another 3dB for a net of 6dB.
/Peter
Old 24th January 2003, 01:10 PM   #28
Great to be back in the special triangles of things eh? Thanks a lot guys I understand now...Unfortunately with noise-cancellation you get a white noise that is evident in almost any noise cancellation (headphones for example). And that, nois-cancellation is always a bit behind in time.
So, by reversing the polarity on the tweeter you get a +3dB. increase where the waves are identical because reverse polarity=pi/2 (90 degrees).
Thank you!
Sorry about the somewhat off topic part of things.
Old 24th January 2003, 01:31 PM   #29
Wizard of Kelts
I did not know that, since I never had occasion to experience "anti-noise". Still, I would guess that the residual white noise is much lower in amplitude than the sound of jet engines. I believe that it actually is used on some aircraft-not certain.
Yes, noise cancellation is always a bit behind in time, therefore it is not 180 degrees cancellation. But even 170 degrees out-of-phase goes a long, long way towards cancellation.
If you reverse the polarity of a tweeter, or of anything, you have just done a 180 degree change, not 90 degree.
What you might have in mind is the reversal of a tweeter in a 12 dB symmetrical crossover. But there, at the crossover point, the drivers are already 180 degrees out-of-phase. The crossover components make them 180 degrees out-of-phase. If you left them like that, cancellation would occur at the crossover frequency and you end up with this large hole there.
So when you reverse one driver, (usually the tweeter, but it could be the woofer), you reverse the phase effects of the crossover, and the woofer and tweeter are now back in phase.
Old 24th January 2003, 01:36 PM   #30
Wizard of Kelts
Details, please. I would really like to find out that story.
Full Range Open Baffle and 5W triode pforeman Full Range 6 12th August 2009 01:18 AM
DIY Open Baffle Full Range Speakers from Wal-Mart . . . loudandclear Full Range 61 29th July 2009 10:01 AM
Building full range open baffle? Glowbug Full Range 27 22nd January 2007 10:15 PM
For Full Range With Subs -- Sealed Box Vs Open Baffle ? DrDeville Full Range 4 21st January 2007 05:26 PM
full range (open baffle) then_dude Full Range 15 9th March 2004 02:58 PM
Copyright ©1999-2017 diyAudio
