Im going to build a pair of MLTLs that will use one of two Eminence drivers. I looked closely at both and modelled both and the results are almost the same. Both appear to be built with the same motor/frame etc, but one is a "bass guitar" driver and the other just a generic pro driver. The cost difference is about $20 each, with the cheaper guitar version using a hemp cone.
Anyone use either of these or have some suggestions? I wont cross them any higher than 800hz. http://www.partsexpress.com/pe/showd...number=290-591 http://www.partsexpress.com/pe/showd...number=290-516 amt |
#2 |
You might want to simulate this one
One of your drivers shows a very nasty rise in FR which is visuable in impedanse curve, and the other driver with hemp cone is almost the same the Legend B102 shows a much nicer impedanse curve http://www.partsexpress.com/pe/pshow...95&ctab=2#Tabs |
#3 |
Sorry, the rise in FR appeared to me as 10db, and its actually just about 5db
| BR, TL, or MLTL? | 00600 | Full Range | 0 | 26th January 2009 01:40 AM |
| Mltl-48 | keladrin | Full Range | 1 | 23rd October 2007 03:57 PM |
| Help newbie with low budget Magnificat/MLTL hybrid project AN8 + Eminence Alpha 10? | klykx | Full Range | 1 | 9th October 2006 03:22 PM |
| Is this a TL/MLTL? | Tuliman | Multi-Way | 5 | 15th April 2006 03:38 AM |
| Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application | esaias | Subwoofers | 8 | 10th August 2005 05:17 AM |
| Page generated in 0.06942 seconds (67.36% PHP - 32.64% MySQL) with 11 queries |
