Hello,
A friend has a pair of McIntosh ML-1C speakers. He is trying to convert them from 4-way to 3-way, perhaps Linkwitz-Riley, I think. We're not sure what order/design is being used in the crossover in the image attached. Can anyone help identify what design is being used? Thanks! |
#2 |
The electrical design of a crossover is not the required acoustic design. ML-1C Loudspeaker system, 4-way bookshelf system has : 12" woofer, 8"lower mid, 1-1/2" soft dome upper mid and 2-1/4" tweeter. Crossover frequencies: 250 Hz, 1.5kHz and 7kHz Impedance: 8 ohms Output: 89dB @1w/1m Power rating: 100w Size: 26"H, 15"W and 13-1/2"D Weight: 64lbs. Sold from: 1970 to 1975 Last retail price: $399.00 each W is 1st order electrical low pass with zobel LM is 1st order electrical low and high pass UM is 1st order lelectrical low pass and 2nd order electrical high pass T is 2nd order electrical high pass note the acoustic slopes are not known, the c/o points above should be acoustic, not electrical. |
#3 |
Thanks, sreten! I admittedly don't know a lot about crossovers. I have been doing more with single-driver designs. Your point about electrical versus acoustical turned what little I thought I knew about crossover design into confusion, but I have a few books on order and will read more about it.
Thanks again! |
#4 |
At its most basic - all drivers exhibit their own rolloff at the top / bottom of their operating ranges. This natural rolloff - combined with any electrical crossover slope gives the acoustic rolloff.
For example. Take a theoretical midrange driver that is already rolling off at 200Hz down to 100Hz at a rate of 6dB (first order being one octave between 200Hz and 100Hz). Put a 1st order highpass crossover on the midrange (so it can crossover to the woofer) - you will end up with a 2nd order acoustic slope (more or less). The 6dB of electrical slope combines with the drivers natural 6dB fall from 200Hz to 100Hz to give a 2nd order (12dB) slope. Cheers, David. |
#5 |
Hey, Dave...
That makes sense now. Thanks for the explanation! |
| Crossover design | hybridfiat | Multi-Way | 27 | 20th July 2008 01:07 PM |
| Identify Crossover? | neddyboy | Multi-Way | 6 | 5th July 2007 08:48 AM |
| Help - identify proper crossover wiring | tleonard | Multi-Way | 3 | 17th March 2006 01:40 PM |
| Looking for tips to identify hum source in a active crossover | ninjanki | Parts | 1 | 26th January 2006 09:17 AM |
| Crossover Design | argonrepublic | Multi-Way | 2 | 14th July 2005 05:45 AM |
| Page generated in 0.09541 seconds (67.25% PHP - 32.75% MySQL) with 11 queries |
