CO8V, looks good! maybe in a MlTL?
Old 12th May 2007, 10:36 AM   #1
Jacobus is offline Jacobus  Netherlands
Default CO8V, looks good! maybe in a MlTL?
Hi guys,
I'm very tempted to buy a pair of the new 8inch co-ax drivers from hemp. They look interesting albeit not cheap!
Anyway, I was wondering what kind of enclosure would work for these drivers? I was hoping for a nice deep bass from a mltl? Is there anybody that can run a sim for these drivers in a mltl enclosure?
Is there anybody here that heard these drivers?
Jacob
Old 12th May 2007, 04:07 PM   #2
GM is offline GM  United States
GM's Avatar
Specs?
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th May 2007, 04:51 PM   #3
Hi Greg,
here is the link to the pdf with specs
http://www.hempacoustics.com/CO8V_-_...heet_ready.pdf
How are things going?
Jacob
Old 12th May 2007, 05:39 PM   #4
GM's Avatar
Greets!
All things considered, doing OK. How about you?
Impressive looking driver, though unless driven with a high output impedance won't go low in a MLTL with any authority unless corner loaded. A BIB pipe horn OTOH will take you down into the 20s........
BTW, woofer efficiency calcs to 89.36 dB/W/m, so forget the 'pie-in-the-sky' 97 dB spec, and based on the 9 g Mms spec, Sd is only ~118.5 cm^2, way too low based on its picture, so I have to wonder how accurate all these specs are.
So, which way you want to go assuming you're still interested?
GM
Old 13th May 2007, 08:26 PM   #5
Well, 2006 was a very rough year but things are going pretty good now.
mmmm, I have some doubts about the driver I have to say. So I think I will skip this idea, I was just playing around to do something with a nice co-ax driver but maybe there are others available suitable for hi-fi that are better.
cheers,
Jacob
Old 13th May 2007, 09:29 PM   #6
GM's Avatar
Greets!
Glad you got it turned around!
B&C gets many favorable references from folks who have a clue, then there's GPA's remake of the Altec 604-8H if you have the budget/space. Adire's HE12.1 kit was the only inexpensive co-ax I liked and it pounded pretty good in a MLTL, but it's gone now.
GM
Old 14th May 2007, 07:16 AM   #7
Thanks Greg,
I will look into B&C, any particulair model I should take a look at?
Jacob
Old 14th May 2007, 09:04 PM   #8
These B&C drivers look pretty interesting;
http://www.bcspeakers.com/index.php?...32&prodotto=57
http://www.bcspeakers.com/index.php?...izione_prod=52
Jacob
Old 14th May 2007, 09:52 PM   #9
Pano is offline Pano  United States
Pano's Avatar
My contact at Hemp Acoustics says that the Coax are his favorite and what he uses at home. Don't know what the alignment is, though. I'll try to remember to ask.
Take the Speaker Voltage Test!
Old 15th May 2007, 03:08 AM   #10
GM's Avatar
Greets!
You're welcome!
No, not really, just that whether pro-sound and HE HIFI types talk about compression drivers, co-axes, etc., they tend to recommend B&C for excellent bang/buck.
GM
CO8V, looks good! maybe in a MlTL?Hide this!Advertise here!
BR, TL, or MLTL? 00600 Full Range 0 26th January 2009 02:40 AM
Hemp CO8V Coaxial inrank Multi-Way 56 7th May 2008 08:30 PM
Mltl-48 keladrin Full Range 1 23rd October 2007 04:57 PM
Is this a TL/MLTL? Tuliman Multi-Way 5 15th April 2006 04:38 AM
Mltl big_kahunah Full Range 2 31st August 2005 03:40 AM
Copyright ©1999-2017 diyAudio
