Old 11th May 2007, 12:36 PM   #1
Send a message via Yahoo to mr_push_pull
Default Crazy microphone calibration ideea
Hello everybody
I've had the ECM8000 for a while, but I really distrust its performance as a measurement mic.
While searching for mic calibration services, I remembered about a discussion on diyaudio concerning DIY methods for calibrating.
Here's my derived ideea. If one could come up with an easily replicable naturally-generated sound, like... 2 cm iron ball falling on flat iron surface or something... and the time response of that, measured in well known conditions would be known...
What do you think?
Old 11th May 2007, 06:51 PM   #2
adason is offline adason  United States
adason's Avatar
you are absolutely right
your ideea is crazy
Old 11th May 2007, 07:43 PM   #3
Send a message via AIM to joe carrow
There's already a method, I believe it's the exploding wire method. A known voltage and current are discharged through a known small-gage wire using a well known circuit. This ensures that a precise quantity of energy is dumped into the system in a well known fashion. Wires can hold very fine size tolerances, and can have very well known compositions.
In order to be valid for calibration purposes, it would probably need to be performed in a large anechoic room. For you or me, that would mean suspending the test rig high in the air, away from any walls or ceilings. It also means that there would be a low frequency where data would become invalid.
Having said that, the ECM8000 really is fairly reliable for most uses. It has good quality control, low variability, and measures very closely to far more expensive microphones. The main place it falls short is at extremely high SPL.
What don't you trust about the mic?
Old 11th May 2007, 08:09 PM   #4
adason's Avatar
exactly!
I have ecm8000 and find it more than adequate for any speaker design work
Old 12th May 2007, 12:32 AM   #5
How about random noise from a pressurized CO2 canister? The continuous nature of the sound, which is akin to a step function, would supply a lot more bass energy compared to an impulse.
Lech
Old 12th May 2007, 01:37 AM   #6
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Default Re: Crazy microphone calibration ideea
Originally posted by mr_push_pull
Hello everybody
What do you think?
I think it's not evident how accurate you are planning to calibrate to.
I have not come across naturally generated sounds that are fully repeatable.
Iron ball falling on an iron surface has lots of problems.
1. If the ball fall on differen points of a surface, the different vibration modes are excited, and material purity also becomes an issue.
2. If the ball fall on the exact same point every time. The surface is diformed differently each time.
3. The ball itself is deformed each time, so regardless whether the contact point is the same ceneter location or not, the actual contact area changes.
Hear the real thing!
Old 12th May 2007, 01:48 AM   #7
Likewise, the CO2 cartridge will sound different based on the orifice through which the gas is escaping, it will sound different as a function of time (because of the changing gas pressure), and it will be dependent on atmospheric conditions (although this is true for any acoustical measurement).
I think that the exploding wire has a lot going for it- but it's pretty irrelevant because the ECM8000 really isn't that bad, and the sound received by the microphone is so heavily influenced by the surrounding environment that it's probably not going to give any kind of high quality results without an anechoic chamber.
Old 12th May 2007, 02:51 AM   #8
Ron E is offline Ron E  United States
Ron E's Avatar
Just send it to Kim Girardin. He can calibrate it for you. Do a search for Wadenhome sound or his name and you will find contact info.
For s's and g's, I once tried to do the reciprocity method using a small speaker as a "reversible" transducer, but I couldn't get enough signal to noise to make it work. Perhaps some more tweeking and I could have got it to work.
For the reciprocity method, you measure the output of a speaker with the microphone you wish to calibrate and also a reversible transducer. Then you measure the response of the reversible transducer, dump all this data into a formula for each data point and calculate the response of the microphone.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 12th May 2007, 03:21 AM   #9
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
If we take a well known human organism like a member of family and feed him a precise quantity of certain beens or something, will he be repeatable?
Old 12th May 2007, 03:47 AM   #10
Geoff H is offline Geoff H  Australia
I have been having problems with repetitive results. My problem turned out to be the photographic tripod I was using. Often showed up as a deep hole at about 200 Hz.
"If we take a well known human organism like a member of family and feed him a precise quantity of certain beens or something, will he be repeatable?"
No, unless you can calibrate the resultant flatulence. Scary idea.
Geoff.
A Mic Calibration How-To cuibono Multi-Way 3 11th June 2009 11:10 AM
Aleph and F5 amp calibration dhole Pass Labs 2 24th April 2009 11:52 AM
Using Yamaha receiver calibration microphone for speaker testing? camshaft Multi-Way 0 25th March 2008 04:07 PM
Amp Calibration in SW arc2v Multi-Way 7 29th February 2008 06:38 PM
Gm emulator for calibration astouffer Tubes / Valves 5 7th February 2007 07:47 PM
Page generated in 0.10826 seconds (81.35% PHP - 18.65% MySQL) with 11 queries
