Many years ago Wilmslow Audio did a loudspeaker kit called ‘Electrostatic one‘, I think. The small electrostatic panels would arc at highish volume levels. Anyway, the mid/base unit was a Volt BM220DS which I’m considering the possibility of using this with a ribbon tweeter in a two-way design. I estimate the crossover frequency would need to be about 2500-3000kHz? Could anyone recommend a suitable ribbon drive unit, something like the ones from Pinsh! but not available as a DIY drive unit I expect. Any gems out there?
WANTED: Creek Destiny POWER amplifier |
#2 |
Dear dyno,
This may not be universally agreed with, but may be useful: www.zaphaudio.com/nondomes/ Cheers |
#3 |
#5 |
I'm considetring the visaton magnetostat, not a true ribbon but a good tweeter I think. the Precide Heil amt is interseting but probably not available for diy.
any thoughts on crossovers!
#6 |
Visaton is a good choice. If you want to use AMT, you can consider the Eton ER4 or the Mundorf AMT tweeters (both are very expensive).
#7 |
How would you compensate for different sensitivity in your tweeter/mid-base units, in the crossover I mean. I have an old version of this:
http://www.voltloudspeakers.co.uk/Lo...y_bm220_8.html which I already have a reflex cabinet for and would have the tweeter atop of it in its own little housing. At the moment I’m thinking of partnering it with a Visaton MHT 12 which apparently needs a 12db, 2nd order crossover (at 3000khz). Any thoughts you experts…!
#8 |
#9 |
UPDATE… if anyone’s still interested…I've been doing research
Still in the thinking about it stage… a 2nd order crossover; I have some capacitors, and resistors for sensitivity balancing (called a L something), will get some inductors calculated to nearest: .68mh somewhere to start from. As for phase, if the tweeter is set back from the mid/woof @ 3000hz crossover would that do instead of reversing the polarity of the tweeter? And by how much? Is there a calculation or by trial & error? |
#10 | |
Did it Himself
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate | lduarte1973 | Multi-Way | 3 | 16th June 2009 08:50 AM |
| Ribbon tweeter | f.bcn | Multi-Way | 0 | 3rd January 2007 06:05 AM |
| Advice for DIY ribbon tweeter construction. | Puggie | Planars & Exotics | 3 | 5th May 2006 05:53 PM |
| Titanium tweeter vs Ribbon tweeter | goldyrathore | Multi-Way | 14 | 17th May 2004 07:21 PM |
| Page generated in 0.09707 seconds (81.55% PHP - 18.45% MySQL) with 10 queries |
