Old 11th May 2007, 09:58 AM   #1
Nordic is offline Nordic  South Africa
Nordic's Avatar
Default Kharma's $1-Million Speakers Blow a Hole in Everything
There is spending a lot of money on your sound system at home. And there are expensive speakers. And then there is Grand Enigma, from Kharma (I think the H signifies "H-H-H-How much?"). A million bucks-worth of high-end audio. So, let's get this straight. Some homeowner from Belgium has chosen to spunk $1,000,000.00 on his audio system (compared with around $1 on the fresco that adorns his walls) in order to show that he is considerably richer than youse. For that money, he might as well have funded an entire orchestra. – Ad Dugdale
http://blog.scifi.com/tech/archives/..._dollar_1.html
Old 11th May 2007, 10:15 AM   #2
That's the largest point-source I've seen so far !
Charles
Old 11th May 2007, 10:22 AM   #3
bigwill is offline bigwill  United Kingdom
Can those things even image?
Edit: Oh I see, they have a line source in the middle and woofers on the edge, they probably image quite well. At first I thought it was just a huge mess of drivers!
Old 11th May 2007, 11:45 AM   #4
Foxx510 is offline Foxx510  Australia
I wonder how they sound in that not quite dead room...... It looks like the room from my sound engineering nightmares........
Old 11th May 2007, 03:30 PM   #5
Ah yes...
So there appears to be a total of 18 sections, amounting to just over $50k each...
I'm sure someone's willing to do a clone costing about a thousand times less!
Lech
Old 11th May 2007, 04:29 PM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
And here if you are interested what comes after Kharma in an expensive loudspeaker classification:
http://www.higherfi.com/spkrlist/speakerlist.htm
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 11th May 2007, 06:18 PM   #7
Holy crap. Most of those systems have major things wrong with them just by inspection.
Let's look at that million dollar Kharma, for example. Sure it's a line source, but the imaging will be trashed by the space between the mid/high cabinets and the woofer boxes causing a first reflection of the surface wave. The spacing between the three mid/high cabinets will also contribute a first reflection and serious comb filtering as a result.
Few very large systems are anywhere near time-coherent: usually stored energy and variable delay paths end up smearing the sound. Even the Wilson X-1, not in the very large class, had problems with tweeter reflections off the mid cabinets.
Old 11th May 2007, 06:28 PM   #8
adason is offline adason  United States
adason's Avatar
my favourite, Genesis 1.1, seems quite a bargain after all...
Old 11th May 2007, 11:42 PM   #9
And none of them appear to be selling a complete 'system'. The emphasis is on just the loudspeakers, which are all (except maybe the Cabasse) very fat and grandiose with nothing in the way of new technology, WAF or anything.
How about plasma tweeters that use solid state electronics and RF MOSFETs?
Multi-amping with digital crossovers? Microphone calibration?
Sleek box shapes without parallel edges or sharp corners? And what's with all the horizontal MTM designs? I thought HT designers did that as a compromise when there wasn't enough room between the floor and the tv for a vertical arrangement?
Lech
Old 12th May 2007, 12:52 AM   #10
how about that audio note on the list.108k for a 8" 2way in a plywood box!!
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 06:11 PM
Setting power amp so speakers don't blow (help a novice) drumstruck Solid State 0 29th May 2009 02:23 AM
can computer speakers blow? sjm3100 Multi-Way 2 21st June 2005 08:36 AM
Speakers Causing Amps to Blow? Old Corps Everything Else 3 1st May 2004 12:03 PM
Page generated in 0.09045 seconds (84.50% PHP - 15.50% MySQL) with 11 queries
